Quickest way to achieve this in PSP 8?
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
Using PSP 8 I want to thicken the profile line shown here:
and at a zoomed level:
so that it looks more like this (which I did tediously and rather clumsily with the paintbrush):
Can anyone recommend a way to automate this reliably please?
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Quickest way to achieve this in PSP 8?
Post by LeviFiction »
For automation, first duplicate the layer so you can remove any unwanted changes.
Under the Effects menu you should have an "Edge" effects option. Use the "Find All" command. It'll thicken all of the lines. Including the compression artifacts.
Then use "Threshold" to get rid of the artifacts.
That should get you a thicker line.
terrypin
ram: 32 GB
Post by terrypin »
Thanks, I'll try that in the morning.
Won't it thicken the other lines too though?
ram: 6 GB
That's why I said to do it on a duplicate layer. You can erase the other lines. And technically you'd only have to replace the numbers if you don't mind the side lines being thicker.
terrypin
ram: 32 GB
Post by terrypin »
Perhaps I've misunderstood your instructions but I don't see how that achieves what I'm trying to do?
This is the result of applying Effects > Edge Effects > Find All
Perhaps you meant Effects > Edge Effects > Erode ? That gives this:
If I repeat that but with just the area inside the frame selected that gives this:
That's the most promising approach so far, but leaves me with the task of cleaning it up.
I'm wondering if alternatively there's a way to duplicate just the original profile line and displace it fractionally above or below the original? But that needs some way to select just the line and not all the messy adjacent pixels.
Note that the target image I showed had already been processed to get close to the result I wanted except for the all important irregular profile line. So I don't want other lines further affected. FYI the original looked like this:
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
Edge Effects > Find All works differently in PSP8 than in later versions for some reason. I ran into this when trying a tutorial once.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
ram: 6 GB
Well, without the background bars you could select the inner portion of the graph. Copy it. Then, make sure you have White setup as your background color, do a "Paste as Transparent Selection." This will let you position the selection slightly above the current line. And you can do it again and position it slightly below the line as well.
IF you find that doesn't work, you can promote the select to two new layers (to keep their place). Change their blend modes to Multiply to get rid of the white. THen position each layer where you want.
terrypin
ram: 32 GB
Post by terrypin »
Thanks!
At first both methods left me with a mess of pixels to remove, but then I added the obvious initial step of maximising contrast. That got rid of the 'aliasing' and/or JPG artifacts or whatever they're called in my original image. (It changed my green line to black but that's easy to fix later.) Your methods then got me the result I wanted. I'd never before used either 'Paste as transparent' or the Multiply mode (or any mode apart form Normal), so that's a very useful lesson.
On balance I preferred the Multiply mode method. I had to zoom considerably to make the selection inside the box and with the first method it was then difficult to position the paste. Although the mode method re-introduced some unwanted shaded pixels around the line, these proved reasonably easy to remove.
I
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Post by photodrawken »
Does PSP8 have the Pen tool? If so, simply click along the original line to create a new vector line on its own layer:
Uploaded with ImageShack.us
Ken
terrypin
ram: 32 GB
Post by terrypin »
Thanks Ken, hadn't tried that but it could well be a possible alternative. But how long did it take you? From this test with the first 2 miles (which took me about 45 seconds, but I reckon I could improve on that) I'd estimate the whole line would take me 3 or 4 minutes, assuming I was trying to maintain accuracy.
That's still a lot faster than using the paintbrush - and very much more accurate. But not as fast and elegant as the 'automation' methods.
Were there any special settings of the pen I should have used?
photodrawken
ram: 16Gb
Hi Terry,
Using the small "complete" image you posted, it took me about 2 minutes to do the whole line. No special settings, just made sure that "Connect segments" was checked, the colour was set to a green, then I zoomed in on it and kept clicking away.
I can't imagine all the rigamarole of the "automation" methods, including cleanup and re-colouring the line would be faster....
I always like to separate the components of an image like this one so that I can easily modify them. For example, having the line as a vector on its own layer allowed me to duplicate it, change its colour to red and use a rectangular mask to only show the area above the 500-foot altitude to emphasize that:
For the sake of experimentation (and completeness), I re-created the entire darn thing with numbers, labels, lines and title on their own separate layers as vector objects. Since it's a relatively simple graph, it only took about an hour. Then I went nuts tarting it up. :wink:
That's just a sample (appropriate for a report cover, brochure or Web banner) to show how flexible it is to have the individual components on their own layers.
Ken
terrypin
ram: 32 GB
Post by terrypin »
Hi Ken,
Thanks a bunch, much to think about there!
For further info, the context is that I print out a map of all my walks/hikes and for those with any significant climbing I add an elevation profile like that under discussion. It starts off looking like this:
https://dl.dropboxusercontent.com/u/401 ... iginal.jpg
and ends up on a sheet of A4 like this:
https://dl.dropboxusercontent.com/u/401 ... -Final.jpg
Note that I quickly eliminate the grey grid and replace the text, to give a starting point for the line thickening task like the one I showed earlier:
https://dl.dropboxusercontent.com/u/401 ... Trying.jpg
Despite the years I've been using PSP8 I'm still not experienced with many of its features. For example, starting with that original JPG, exactly what steps would I follow to get "... the line as a vector on its own layer" please?
I'm off for lunch with my wife shortly but hopefully will experiment further with your pen method later today.
photodrawken
ram: 16Gb
Hi Terry,
Yeah, I don't like eliminating the gridlines because that only makes the graph harder to read.
From where do you get the graph? Do you draw it yourself, or is it already drawn by another source?
Set the options for the Pen tool to "Create on Vector", then simply starting to draw the line will automatically create it on its own vector layer.
Edit:
That's how it works in PSPX5. With PSP8, you might have to first create a new vector layer and set the Pen tool to "Create on vector" -- I don't know exactly how that version worked....
Ken
ram: 6 GB
*side query, not at all helpful*
I would also like to know where this elevation data comes from. It's interesting. Also, do you take the "official" walk-ways or make your own? Part of that looks like the Broadstone Amble pathway, but overall it's a lot narrower.
terrypin
ram: 32 GB
Post by terrypin »
Thanks Ken.
Ken, LeviFiction,
My walks are captured by GPS using Memory-Map on my smartphone, an aging HTC Touch Pro 2 using Windows Mobile. I download it to Memory-Map on my Windows XP PC after I get home and save it as a GPX file. From Memory-Map's screen I capture the walk region and paste to PSP8 and add the title, statistics, etc.
As mentioned, in a minority of cases I also prepare an elevation profile using one of two methods. The one discussed so far is a feature of a program called GPS Utility
http://www.gpsu.co.uk/download.html
which lets me adjust the axes, etc.
Alterrnatively, Memory-Map itself has a similar facility. In fact it can directly display two types of profile:
1. A GPS based profile, using the data from the actual walk. As you see, this is unsmoothed, recording every twitch and satellite signal error.
https://dl.dropboxusercontent.com/u/401 ... MM-GPS.jpg
2. A profile based on the elevation data in the map itself (usually the OS 1:25k), which is obviously smoother but not necessarily more accurate (for several reasons).
https://dl.dropboxusercontent.com/u/401 ... M-Elev.jpg
But although that looks good and avoids the thickening issue, neither allow me to reduce the Y-axis to sea level, which is my preference. Hence my usual choice is GPSU.
I haven't done so but you should be able to see any overlap with the Broadstone Amble in the same area from the detailed map I posted earlier:
