Adding effects to Corel VideoStudio X5
Don F
motherboard: TOSHIBA Portable PC Base Board Version
processor: 2.20 gigahertz AMD Turion X2 Dual-Core
ram: 6 GB
Video Card: ATI Radeon 3100 Graphics
sound_card: Realtek High Definition Audio 6.0.1.6662
Hard_Drive_Capacity: 1429.28GB
Monitor/Display Make & Model: Generic PnP Monitor 15.9" + Viseo26L HDTV
Post by Don F »
Hi everyone. I'd like to add downloaded vst & vfx files to Corel VideoStudio X5 library... I'm not having any luck with the vfxs and haven't a clue with the vsts. Anyone?
Thanks.
Don
Re: Adding effects to Corel VideoStudio X5
Post by BrianCee »
As far as I am aware VideoStudio only uses vfx files for the transitions - I do not think VS has the capability to edit them.
The vfx files which VS comes with can be found here :-
C:\Program Files (x86)\Corel\Corel VideoStudio Ultimate X5\Vfx_plug
you could try adding your files there but that will not put them in a library that you can use.
as I say I don't think VS can edit them - have you tried just importing them to a library ? - what error do you get ?
and as for .vst - they are not listed anywhere as compatible with VS - .wav or mp3 is about all you can use.
Don F
ram: 6 GB
Post by Don F »
Hi Brian. No I hadn't tried importing them... I guess you mean the same as one would add media. I had dropped them in the vfx_plug folder followed by restarting the program, rebooting the computer... anything I could think of to get them to show up. Just now, I've noticed that I had downloaded an .exe file with the series of 24 .vfx files but it won't open & it's not zipped. I'll play with this some more & let you know how it goes.
I looked a little further for .vst files & found that the NewBlue audio plugs are .vsts. Now that I know where in VS to find some .vst files I'll play around with that too.
Thanks for the input.
Don F
ram: 6 GB
Post by Don F »
Brian! I forgot to mention! I found the .vfx files among the "Steve's free stuff" postings & wanted to thank you for posting the referral. Steve has a lot of great stuff in there.
Don
Post by BrianCee »
I just tried to import a .vfx into a library and get a 'file format mismatch' error - so that doesn't seem possible either.
Don F
ram: 6 GB
Post by Don F »
Hey there Brian... Me too. I hadn't used "import library" before but tried & got the same results as you. Thanks for the suggestion though.
Dropping audio .dll files in the NewBlue VST folder works well on the other hand. I added some basic, classic audio signal processing to my audio effects. The interfaces work perfectly & having a classic compressor & hard limiter is a huge help. Also helpful... a parametric EQ & a flexible noise gate. The only problem is that while adjusting compression I was limited to sampling adjustments at the beginning of the audio clip. To adjust settings appropriate to the audio dynamics in the middle of the clip I had to scrub through it, stop & reopen/ readjust the compressor then scrub again. The same compressor in my Audio MixPad app, such adjustments can be made on the fly.
It's nice to have plenty of practical tools on hand. Posting this might inspire anyone who hasn't tried adding .vst or .dll files.
Don
Hi Don
Sometimes after adding plug-ins and filters we need to reset the program to allow the libraries to populate with the new files.
If this does not help and you need your old libraries structure, simply re-place the 15.0 folder with the old one.
Resetting VideoStudio Pro X5 to Factory Defaults
