VS X5 Ult. causing crash on DVD Import
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I am running XP and X5 Ultimate.My workflow follows :
File
Insert media file to library
Insert Digital media
Select drive in import from digital media box
Start
Then the screen goes black and the PC reboots with an error report box showing.
The DVD has a UDF file system and it is 2.32GB and plays in Power DVD ok
What can I do to solve this problem ..................Ken
Re: VS X5 Ult. causing crash on DVD Import
I run X5 on Win 7 machines. When I follow your workflow, the Import From Digital Media box shows correctly and indicates my DVD Drive and the video in it...
Have your tied simply right clicking in the timeline and choosing Insert Digital Media? (Mine behaves the same way as it does in your workflow.)
Have you tried using Windows Explorer to copy the contents of the disc to your hard drive, and then tried it from there?
Failing all else, have you imported it with Windows Explorer, then simply changed the .vob extensions to .mpg and inserted them?
Ken Veal
ram: 32 GB
Post by Ken Veal »
What more can a member ask for? .....Quick response and problem solved-thanks Ken.
Here is my new workflow
In the box that appeared after DVD insertion-
Open folder to view files
Right click timeline
Insert digital media
In box select drive
Start
Content folder shows in Import form dig media box
Titles and chapters populate
Select items to import (Select all clips option is at top)
Can browse to change working folder
Start import
Progress shows
File imported to time line
