Every conversion of the same RAW results in a different JPG
Bugs & Suggestions
Matagalpa
processor: i5-750
Video Card: AMD HD 7850 2GB
Monitor/Display Make & Model: Dell 2209
Post by Matagalpa »
I just noticed something very odd. If I keep the same conversion settings and just save the file again (using a different name) I get a file which is not binary identical to the previous one. This happens every time I save the file. See the files size column here:
None of these files are identical, and the differences are not in some metadata part, they are in the actual image. If I view the converted files using very high magnification (e.g. 1000%) it's very easy to see that pixels are different.
I'm using version 1.1.0.30.
Is this a known bug?
SteveCase
System_Drive: N/A
motherboard: ASRock 990FX Extreme4
processor: AMD FX-8350
ram: 16.0 GB
Video Card: GTX 550ti
Re: Every conversion of the same RAW results in a different
Post by SteveCase »
Just ran a test. File output is identical no difference on my Win7 machine.
Take a RAW and make sure there are no settings being applied and try again. See if this makes a difference.
Steve in Seattle,WA
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Perfectly clear?
cheers
afx
