To get this lens auto-recognized on the OM-D, I had to modify the file profile_olympuslenstable.txt
I did comment out the line
0 4 16|Zuiko Digital ED 9-18mm f/4.0-5.6
which is for the four-thirds version and instead inserted
0 4 16|M.Zuiko Digital ED 9-18mm f/4.0-5.6
The M. makes all the difference!
---M
Olympus mFT Zuiko ED 9-18mm f/4.0-5.6 auto lens recognition
Re: Olympus mFT Zuiko ED 9-18mm f/4.0-5.6 auto lens recognit
Hello
Here is the values for correction for the 9-18 mm Lense.
begin lens
group: micro43
multiplier: 2.0
aperture: 4.0
calibrated: true
menu_lens: Zuiko Digital ED 9-18mm f/4.0-5.6
cal_abc: 9.0 -0.01397 -0.00132 0.00746
cal_abc: 10.0 -0.01510 0.00629 0.00151
cal_abc: 11.0 -0.01606 0.02292 -0.01323
cal_abc: 12.0 -0.01257 0.02188 -0.01427
cal_abc: 14.0 -0.00955 0.02238 -0.01717
cal_abc: 16.0 -0.00227 0.00203 0.00307
cal_abc: 18.0 -0.00053 -0.00094 0.00420
end
begin lens
group: micro43
multiplier: 2.0
aperture: 4.0
calibrated: true
end
G0bble
- motherboard: 880GM gigabyte
- processor: Athlon X4 3.6Ghz
- ram: 12GB
- Video Card: onboard
- sound_card: onboard
- Monitor/Display Make & Model: Dell U2414H
- Corel programs: VSx10.5 Aftershot Pro 2/3
So where exactly do I place the above data? Is it inside profile_olympuslenstable.txt? Or inside profile_olympus.txt ?
You put them in 'profile_micro43'. find the 9-18 lense and replace the lines with the calibrated values.
Regards Per
Regards Per
G0bble
- ram: 12GB
Thanks. That worked.
I see in this other thread that you originally used Hugin and somebody (sesquiped) posted a different set of vaules. http://forum.corel.com/EN/viewtopic.php ... us#p253187
Did you try those? Which ones are you using now?
--G0bble
--G0bble
I use them posted in this thread. The new values is much better in the low end.
Regards
Per
Regards
Per
