VSPX6 Ultimate Rendering Issue
Klindar
motherboard: ASUS P77 Deluxe Gen3
processor: I7-2600K
Video Card: AMD Sapphire 6970
sound_card: Realtek High Definition
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: Dell U2711
Corel programs: Paintshop Pro Ultimate, Video Studio
Post by Klindar »
I have had this product for about a week and it is fabulous compared to any other video editors I have tested.
There is something odd happening, however. I am using the Mercalli plug-in to stabilize hand-held videos. This works great but the rendered video always has a message overlaid saying the Mercalli analysis must be re-run (even if it has just been done). There IS an exception: render to mpeg4 and everything's fine - stabilization has been applied and no message. If I then take the exact same project (no changes) and render into AVCHD (for example), the output is ruined with the overlay. If I go back into the project again to have a look at what's up re-analysis is NOT called for.
Best wishes,
k.
Re: VSPX6 Ultimate Rendering Issue
Well yes I also see the same. I have used Mercalli in the past, not so long ago with no problems.
Very strange, maybe others can confirm your findings?
I will do a few more tests?
Oh thanks for the info
Klindar
processor: I7-2600K
Post by Klindar »
Thanks for confirming. I am quite happy with MP4 for now but will eventually need other formats. Will also do some more tests and report findings.
k
Post by BrianCee »
What are we actually rendering to - I have not noticed this in any of my videos and I just specially rendered out another using AVCHD(1920x1080) - are you using any of the 24p/25p/50p options.
Hi Brian
I used the sample balloons from the library, added Mercalli and customised to scan as Fimnal Result.
Then returned to the timeline Share Create Video File – DV retained the warning notice to the new video file.
The video Analysis must be run again, and contained the darker filter associated with this warning.
It is definitely embedded to the video file and I am sure I am using it correctly.
I have tried a few formats, when I did mpeg2 and rendered Same as First Clip it worked ok.
I have never seen this before when I have used Mercalli in the past.
I am running X6, also tried X5 with similar problems.
I am totally confused as I don’t think any thing has changed.
Just about to give the Laptop a run?
Post by BrianCee »
if I take the balloons sample which is a .wmv - apply the filter and then analyse then render a DV file - then the warning and dark overlay appears in the output file.
If I take one of my .avi files and do exactly the same then I do NOT get the warning and all is good.
If I take one of my AVCHD flies and repeat the process then again I do NOT get the warning and all is good.
on my laptop it seems to depend on which file I start with.
Thanks Brian, that’s the conclusion I came to, depends on the type of file being used.
But should be ok with all types…………
I will try a few more video formats, but Mpeg types seem ok, and your Pana 700 samples don’t have a problem.
May have to wait till tomorrow now
Oh I did try disabling Smart Render which does help for some problems, no change there.
I seem to recall a much earlier thread, possibly associated with Mercalli in X5, which indicated that the output, after applying Mercalli, had to be frame based/progressive. Certainly that accords with my own use of the filter for both HD and SD output.
For instance, I have just used an AVCHD clip, applied the filter and then Share > Create Video File > DVD, accepting the defaults including Upper Field First. The output has that message and darkening applied. However, when I chose Share > Create Video File > Custom, selected SD mpeg-2 as the output format, and changed UFF to Frame Based, the output was very good and did not have that message.
The same also happens if I choose Blu-Ray mpeg-2 as the output, and accept the default which includes UFF. But if I go the Custom route and select Frame Based, no message. Ditto for AVCHD. WMV works straight off, I assume because it is Frame Based in the Corel defaults.
Hi Ken
There must be more to this, I used the Balloons sample, that’s Frame Based WMV and the problem was there.
I also converted a video some time ago using Frame Based Mts H264 and that is ok.
Ten pin bowling this morning, so will test later.......
Klindar
processor: I7-2600K
Post by Klindar »
Colleagues,
I bought a ticket ($20) and put in a request to Corel for assistance with this. They sent the document included, for your consideration, as text at the end of this posting. Following those steps I still get that message overlaid on my output but .mp4 remains fine. I will fool with this some more later today. IMO if we have to go through "Custom" settings to avoid this problem then that's a workaround, not a real solution but ... providing it can be made to work (which so far I cannot) that's quite acceptable for now. Presumably this will get fixed in a future release or patch.
I will post any additional findings here.
My "ticket" remains open at Corel for now. I could pass on any additional information from you and assume this will be OK by them.
Best wishes,
k.
In some cases a finalized product (either a video file or disc) will show this message in the finalized
product after adding the Mercalli 2.0 stabilizer plugin to the project:
Video effect proDAD Mercalli:
The video analysis must be executed again.
To resolve this issue, please follow these steps:
Add your video to the timeline
Apply the proDAD Mercalli filter to the project
Click on the Share Tab
Select Create Video File from the options
Click on Custom
Change the Save as type selection to MPEG Transport Stream Files (*.m2t)
Click on the Options button
Click on the General Tab
Change the Frame rate to 29.97 frames/second
Change the frame size to your desired dimension
Optional: Click on Compression Tab and drag the slider to the right to adjust for quality
Click OK
Name your File
Choose a location for your File (recommended Desktop for easy retrieval)
Click OK
Click Save
Next, click File and then New
Your newly created file will now be in your library section along with the other media thumbnails
in VideoStudio Pro
Trevor -- I just used the balloon clip you mentioned (V14), applied Mercalli, used the Customize Filter on it, then rendered to a new WMV, and it worked perfectly, as had my previous use of V01 (the plane wing).
Hi Ken/Klinder
Thanks Ken, I have re-tested the "balloons" again, rendering to WMV does seem ok, it is when you convert to another format causes problems.
I have tried a variety of formats Mov, DV, Mpeg2, Mts etc and all seem ok only when using WMV and rendering to another format -- DV for instance gives the problem.
I have also tried a variety of field orders/frame based all ok.
Klinder
What type of video are you using?
Are you using the samples from the library.
