mFT Lens Calibration: M.Zuiko Digital 17mm f/1.8
Tips, Tricks, and Results
-cr
operating_system: Linux
System_Drive: N/A
Post by -cr »
Not perfect, but good enough for my purposes:
Append to profile_olympuslenstable.txt:
Code: Select all
0 22 16|M.Zuiko Digital 17mm f/1.8
Append to profile_micro43.txt:
Code: Select all
begin lens
group: micro43
multiplier: 2.0
aperture: 1.8
calibrated: true
menu_lens: M.Zuiko Digital 17mm f/1.8
cal_abc:  17.0  0.0035963 -0.0444685 0.0185299
end
netAction
System_Drive: N/A
processor: Intel i7
Re: mFT Lens Calibration: M.Zuiko Digital 17mm f/1.8
Post by netAction »
Thanks a lot!
You should add that the files are in /opt/AfterShotPro/supportfiles/Profiles/LensProfiles.
First the images had a strange saturation and became blue after the patch.
Then I deleted the user settings in ~/.AfterShotPro and the Catalog. Everything works now.
Regards
Thomas
PS: Please publish correction profiles under a copyleft license like CC-BY-SA and don't put them in this forum because Corel could prevent others from using it because of copyright *!*!*, and that might not be intended by you.
gpe
System_Drive: N/A
motherboard: ASUS P8P67 LE
processor: i5-2500k
ram: 16 GB
Video Card: Nvidia GTX550Ti
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Dell U2410
Corel programs: AfterShot Pro 2
Post by gpe »
Thanks for the tip but for me the lens isn't automatically recognized ? Is it the same thing for you ?
-cr
System_Drive: N/A
Post by -cr »
gpe wrote:Thanks for the tip but for me the lens isn't automatically recognized ? Is it the same thing for you ?
In case you imported images before adding the lens profile: Try "reload EXIF" in the lens correction setting for the pictures.
(If that works and you want to apply it to many images: "fix" one image and use it to "copy selective image adjustments -> lens correction" and paste to all other photos taken with the 17/1.8 (use "metadata browser" + "link to catalogs" + "photo info -> ..." to find all of them, then "select all".)
For images imported/loaded after adding the lens profile, it should be automatically recognized.
