I have a script that merge (Flatten) all layers but if an image has a single layer and that layer is a background layer then my script fails.
What comes to my mind is to get a layer count and if that count is 1 then check if that layer is a background layer, if it is then do not merge.
How can i get a layer count and how can i get the layer type of a specific layer?
Are there more resources about scripting in PSP, a library reference or something?
My script is for PSP9 and PSPX5, any help would be great.
Thank you!
Script - Know if layer is background or not
TripleHeinz
- motherboard: Gigabyte GA-B85N-WIFI
- processor: Intel Core i3-4330 [3.5 Ghz]
- ram: 4 GB
- Video Card: nVidia GeForce GTX 750 Ti [EVGA 02G-P4-3751-KR]
- sound_card: Realtek ALC898
- Hard_Drive_Capacity: 960GB
- Monitor/Display Make & Model: LG E2360 [1920x1080p]
- Corel programs: PSP (7, 9, X5, X7), VS (X7)
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Script - Know if layer is background or not
Two ways that I know of to get the layer count.
1) First is to import PSPUtils or JascUtils and using the GetLayerCount( Environment, Doc ) command.
PSPUtils replaced JascUtils in later versions of PSP. However you can still use JascUtils even up to PSPX5 for backwards compatibility with older scripts. In this case since you want to use it with PSP 9 we'll use JascUtils.
Now if you want to make sure it's flat (no transparency) you will also want to check if it's a background layer. If you don't care, then this suggestion can be skipped.
If you want to also make sure it's a background layer before giving up you can include "LayerIsBackground (Environment, Doc)"
2) Or you can program these requests yourself. They are all returned by the basic info.
Hope that helps
Code: Select all
import JascUtils
#If LayerCount is just one
if JascUtils.GetLayerCount( Environment, App.TargetDocument ) == 1:
return
Code: Select all
import JascUtils
#IF LayerCount is just one and it is a background layer
if JascUtils.GetLayerCount( Environment, App.TargetDocument ) == 1 and JascUtils.LayerIsBackground( Environment, App.TargetDocument) == True:
return
Code: Select all
#Grab number of layers.
ImageInfo = App.Do(Environment, 'ReturnImageInfo', {}, App.TargetDocument)
NumOfLayers = ImageInfo['LayerNum']
#Is Layer Background Layer
LayerInfo = App.Do( Environment, 'ReturnLayerProperties', {}, App.TargetDocument)
IsBackground = LayerInfo['IsBackground']
TripleHeinz
- ram: 4 GB
Thank you!!! Yes, it worked as needed (PSP9 and PSPX5). Though i used a different logic:Hope that helps
Code: Select all
if JascUtils.GetLayerCount(Environment, App.TargetDocument) > 1 or JascUtils.LayerIsBackground(Environment, App.TargetDocument) == False:
# Merge All
# Script flow
