Fading In/Out When Using PiP's
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
I am using videos as PiP's and I want to use the fade in/out feature, but am finding that it takes 15 seconds for the fade to complete, some of the PiPs I am using are only 45 seconds long, so to fade in/out is going to take 30 seconds leaving only 15 seconds of full video. Is there any way that the fade time frame can be reduced. In Elements 11, fade in/out takes 1 second and this is what I would like to achieve in X6 if it's possible.
Robert
Re: Fading In/Out When Using PiP's
Post by BrianCee »
I have found the method I provided in this topic here :- http://forum.corel.com/EN/viewtopic.php?f=1&t=50442
can provide fade ins and outs of any length you care to set - it can also provide movement of the PiPs - see if it can do what you want.
:idea:
RobertOZ
Post by RobertOZ »
Thank you Brian, your workaround is just what I need.
Robert
Post by BrianCee »
Variation on a theme here :-
http://youtu.be/pJc0D8CnqYY
could be combined with fade in and out
