Problems with "Adjust" options disappearing X5
MrTango
Post by MrTango »
Hi Everyone,
I have checked through the forums and have not been able to find an answer.
Spec:-
PSP X5 running on Windows 7 Ultimate x64 fully services packed and patched.
When I use the "Adjust" section within PSP you have options on the left hand side also called "adjust".
Within the section you have a histogram display along with Smart Photo Fix, White Balance, Brightness/Contrast, Fill Light/Clarity and local Tone Mapping. I hope this explains where about within PSP I have this issue.
Problem:-
When I start PSP it is in a window and not full screen. I select a photo and wish to, for example, adjust using "smart photo fix". I select this option and for a split second I can see the options within the smart photo fix menu. The options then just disappear. This is the same for all other options within the "adjust section. If I then double click the top menu bar to go to full screen the options return and can use all options. If I "go away" from this section and say crop and image then go back to the "smart photo fix" all of the options have disappeared again. I double click the top menu bar to return to a windowed view and the options return.
Hope you can help.
Regards Dave
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: Problems with "Adjust" options disappearing X5
Post by trueblue »
Hi Dave
I suggest first off, check all your preferences. Make sure you haven't unticked/ticked something.
I don't know why the palette is disappearing on you as it's not a dockable palette like others. Do you see the Instant Effects palette on the right side and also the Organiser below?
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
