PaintShop Pro X4 hangs/freezes
jacqskellington
processor: Intel Pentium Dual CPU T2310 146GHZ 147GHZ
ram: 2GB
Hard_Drive_Capacity: 141GB
Monitor/Display Make & Model: Sony Vaio VGN-NR120E
Post by jacqskellington »
I have had PaintShop Pro X4 for a while now and recently (around December 2012) the program wouldn't even open. It kept freezing up and I had to close it with task manager, so I uninstalled and reinstalled PSPX4. Then it started hanging/freezing every time I try to open or save a file (all types) or copy and paste when editing, and when I select certain tools such as paint brush or text. About 50% of the time I have to close the program with task manager, the rest of the time I have to wait until X4 decides it wants to work so I can get stuff done. Is anyone else having this problem and is there a way to fix this? Will upgrading to X5 fix this problem? I noticed it started after I installed a PSP update, which I think might have been SP3. I have no image files in my documents so it does not load but only 1 picture on start up.
I currently have version 14.3.0.3 and there are no updates available.
I would greatly appreciate any help.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: PaintShop Pro X4 hangs/freezes
Post by hartpaul »
I have a friend with Vista that runs X4 with no problems. He only uses it in Edit mode however. The manage mode has been known to have some problems with cataloging from reading other posts.
The first time you get it operating try changing the default operating mode to Edit and turn off the cataloging.
You say it was operating for a while before the problem. So you need to try and determine what has changed / caused the problem.
Because you have reinstalled the program with the same results it suggests that something outside the program (corrupt database, bad files..) is causing a problem.
Is the program a CD version or a download. I would also try the program on another computer just to verify that you do not have a bad download / corrupted CD.
jacqskellington
ram: 2GB
I will try that, but I don't see how that is going to help the hanging and freezing when I manually open a file in PSPX4 or when tying to edit the picture. I purchased it online so I have the download. I do not save the file to my computer, I log into my corel account and get a new download each time. My mother has it on her computer, I will have to play around with it and see if it does that same thing. Nothing has changed with my computer (programs and such), so I know it is NOT my computer. The program worked beautifully until corel installed on of their updates.
jacqskellington
ram: 2GB
How do you turn off cataloging? I have tried to find a way and as far as I can tell that option does not exist.
hartpaul
ram: 8 Gb
Post by hartpaul »
File > Preferences >General Program Preferences Manage and untick all the boxes. Also on Default Work Space set Edit
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
hartpaul wrote:File > Preferences >General Program Preferences Manage and untick all the boxes. Also on Default Work Space set Edit
I don't think that unticking that actually disables cataloging. It just changes WHEN PSP does it. Normally it will catalog your files when you load the program. Ticking the box tells it to wait and do that after you shut PSP down. Here's the blurb from the Help file:
In the Thumbnail images group box, mark the Allow cataloging to complete after exiting the application check box. When enabled, this option speeds up the display of thumbnails when you next start the application.
To stop the cataloging, I think you have to add your folders to the exclusion list.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
jacqskellington
ram: 2GB
Alright, I did uncheck the "cataloging after exiting the program" and I excluded all the file types, the only thing I did not do was the folders. Even with all that though it did not help. I think I am going to try to uninstall and reinstall it without doing the corel update. I am pretty sure all this started when corel updated to the service pack 3. Thank you everyone for your help.
jacqskellington
ram: 2GB
I got it working properly. I uninstalled and reinstalled PSPX4 (went from 14.3.0.3 to 14.2.0.1), I also stopped cataloging as well because I never use it anyway. It had to be the service pack 3, so I will just not do anymore updates. Thanks for the advice.
