screen capture in VS pro x6
adsadek1
Post by adsadek1 »
Hi every one, I have a new issue with screen capture in VS pro x6. When I try to capture the sound from my computer i.e. a clip on (you tube) when I hit the record button (the red circle) I get this message:
it counts 3-2-1 then…at 1 (Prepare Record Failed!!! #15)
However it works fine if I disable it… when I record my voice when it is screen recording, no problem.
Also, when I try to record a game play, full screen, it stops once I launch the game, a message says that my screen capture is complete without me hitting the stop capture button!!
My computer is running win 7 Prem. Service pack 1 64 bit 12 GB RAM Intel core i7 @ 3.40 GHz
Thanks..
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: screen capture in VS pro x6
Post by RobertOZ »
Well, you are the first person to report this problem with X6, see if the following link for the same issue with X5 helps
http://forum.corel.com/EN/viewtopic.php?f=1&t=49906
Edit.
Whilst you have the opportunity, put in a request to Technical Support using your 90 day free support, maybe they can come up with a solution that actually works, seeing this has been an issue for some users for more than 12 months with X5.
Robert
adsadek1
Post by adsadek1 »
Thank you RobertOZ, I will have a look at the link you've sent.
