VS Pro X4 error:"unable to switch to Capture Mode"
charlesh
Post by charlesh »
VS starts in Edit Mode. After connecting the video camera by a iLink cable to PC and switching the camera to Play mode, clicking on tab "Capture" an error message appears: "Unable to switch to Capture Mode. Check if your video capture driver is working properly"
Question: How do I do it? I am not a computer savvy person, just want to capture, edit and finally burn my videos taken with the camera.
Please advise, thank you.
Re: VS Pro X4 error:"unable to switch to Capture Mode"
Post by BrianCee »
see if this topic helps you find a solution :-
http://forum.corel.com/EN/viewtopic.php?t=23051
charlesh
Post by charlesh »
Yes, thank you BrianCee. Downloading the recommended DirectX upgrade solved the problem.
