At the beginning of the cross fade transition effect the audio drops out completely and suddenly get's loud at the end of the efftect. Please help.
I'm using external USB 2 hdd and USB 3hdd
VS ProX5 and VS12
The properties for my video:
File format: mpeg2
file size-1,173.668
duration-478.378 sec
video format: mpeg-2, upper field
attributes: 24bits, 1440x1080, 16:9
frame rate: 29.970
data rate: 25000
Audio:
Audio type-mpeg audio layer 2
total samples-18, 166,967
attributes-48000hz, 16bit stereo
layer-2
bit rate-384
a. Where did they originate (camcorder, internet, TV card etc) Camcorders-SonyFX1 HDV and Canon XHA1 HDV
b. How did they get onto your hard drive (download, firewire, USB cable etc.) Firewire
Project Properties-
NTSC drop frame (29.97 fps)
MPEG files
24 bits, 720 x 480, 29.97 fps
Upper Field First
(DVD-NTSC), 16:9
Audio data rate: 256 kbps
Please help.
Thanks,
George
Audio jumping out loud at the end of transition effects
gecatgjc
- motherboard: Dell Inc. 0PTTT9 A01
- processor: 3.20 gigahertz Intel Xeon E5-1650 0
- ram: 8.00 ghz
- Video Card: NVidia Quadro 600
- sound_card: NVIDIA High Definition Audio 4x
- Hard_Drive_Capacity: 2tb
- Monitor/Display Make & Model: dell U2410
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Audio jumping out loud at the end of transition effects
Sorry, unable to replicate your issue, audio plays fine through transitions on my system.
You could try splitting the audio from the video, then apply the transition to see if that works, it may be necessary for you to move the audio along the track first, then apply transition, then move audio back.
Robert
Robert
gecatjc - can you expand your timeline to it's maximum then change to sound mixer view and take a screen shot of the area including the transition like mine below - then post it here so we can see what is happening.
