more effects and props
bjb56
Post by bjb56 »
Is there any way to add animation to a slideshow? Also, is there anywhere I can go and download more props. I like the feature of being able to add them but the selection they provide is pretty slim. Thanks
bebop
Post by bebop »
i know what you mean about more props, i've written to ulead to find out if there is a way to import annimations but have not recieved an answer, photshow deluxe has some cool things but u cannot burn to dvd, have you been able to import any clipart into your software other then reg pics, i've tried but that doesn't seem to work either
lambda
Post by lambda »
I called ULead and talked to a Tech on this. Right now, there is no way to add a prop such that it appears in the menu for you to select (we tried renaming files and making new menus - no go). The Tech was able (after about 15 minutes worth of monkeying) to figure out how to bring in a new prop indirectly. First, he created a picture with a transparent background in Photo Impact and saved it as a .GIF. He then pasted this photo onto the slide by using the "Decorate with more photos" button on the Decorate page. Since it had a transparent background, it worked like a prop. I haven't had the time to find any images with transparent backgrounds to test this out. Good luck.
