Color and Brightness Adjustments
Replicarter
Post by Replicarter »
Im currently still using XL as i tride the newer version and it doesent have the Color/Brightness adjustment tools on the tool bar:
Has this been removed or is there a way to add it back to the tool box? I find these better than going into format and changing them from there.
Masami
Post by Masami »
There is a button on the right. It looks like this:
Click that and you get the color panel. It looks a bit different now:
But it should work about the same.
heinz-oz
Post by heinz-oz »
You can also refer to your manual and set PI 10 up like this:
I can't remember how I set it up and haven't got the time right now to do it again for your benefit. It was very easy though.
Give it a try :wink:
keenart
Post by keenart »
While Heinz-oz is asleep here is how you do that:
Go to File, Preferences, General, Categories, PhotoImpact, Tools, check the box named Show the Quick Color Control Panel. Select the OK button. You are done!
heinz-oz
Post by heinz-oz »
:D Heinz-Oz never sleeps, especially not while at work :wink:
Thanks keenart, you saved me from having to look it up myself :P
