I'm adding numerous titles to my project. I'm struggling with how to control the speed which the title scrolls across the screen.
What I'd like is to have the title scroll into position, then for it to remain. I'm finding that if the clip is 20 seconds in length, the title uses the 20 seconds to scroll.
Do I need to put two titles within the section? One that scrolls into position and one that is then static?
Thank you.
Title Speed
From the animate title, select the ‘Type’—drop-fade-fly etc
Now click the two TT’s this gives you more options.
You can select and pause the animation mid way.
If you wish to use more than one title that can be good as well.
Create your first title.
Now drag this title to the library, this made a thumbnail copy of your title.
Now drag the title back to the timeline.
This ensures that the text for both titles is in the same position.
Animate both titles to give the effect you want.
Hope this Helps
Hope this Helps
