Chapter playback & button selection templates?
Mike S
Post by Mike S »
I have now successfully burnt two DVD discs (using MF3 with 12 Mbps MPEG2, rather than DVD std video encoding), with Title and Chapter features, with which I am very pleased.
However, I find that if I select and play a chapter that the disc will play from that point on, to the end of the disc, rather than just to the end of the chapter.
Is there any way that I can compile the disc to either stop at the last frame of the selected chapter or to jump back to the title or one of the chapter selection screens, when it gets to the end of a chapter?
I should also like to be able to select a template with a different number of buttons for each of my chapter selection pages, rather than the same for each, but can't find a way of doing this. Is this possible?
Any suggestions appreciated. Thanks.
ploggy
Re: Chapter playback & button selection templates?
Post by ploggy »
Mike S wrote: However, I find that if I select and play a chapter that the disc will play from that point on, to the end of the disc, rather than just to the end of the chapter.
MF3 does not support this. It will only go back to menu if the Titles are finished (not for chapters). DVD WorkShop, i think is capable of doing this because it has an option to create playlist for menu buttons.
the layout for menus and subchapters in DMF is always uniform. If you set a layout of 3 buttons, whether menu or submenu, all the other menu page will have the same layout. Again, workshop is capable of doing this.
Mike S
Post by Mike S »
Many thanks for your reply. I'll have a look at DVD workshop.
Regards
Mike
GeorgeW
Post by GeorgeW »
afaik, the Playlist feature in DVD WS is a Title Playlist, and not a Chapter Playlist feature. So you cannot play just a chapter, then return to a menu. It will jump to the chapter within the Title, then continue playing until the end of that title, then play the next item in the Playlist.
George
ploggy
Post by ploggy »
tnx for the correction George
Mike S
Post by Mike S »
In case anyone is following this thread, I have found that I can do exactly what I wanted to do by compiling the disc as a series of seperate video segments, which creates coresponding multiple buttons on the title page (s), and forget about creating chapters.
If I now play a segment (having deselected loop play during the authoring), it will jump back to the title page at the end of the sequence.
I have also found that I can simulate a freeze frame, at the end of a sequence, by adding a slide with a long (eg 30 sec) delay.
