sync audio to video with x5
I did not find any tutorial or explanation how to sync audio when it playing too early or too late.
Re: sync audio to video with x5
I am afraid you need to tell us a bit more information
Is this audio integral with the video - or is it from a separate source
Was it ever in sync and editing has caused the problem.
Is it the rendering to a new format which caused the problem
help us to help you by telling us more about your problem
FYI, I have moved your post to the Video Studio forum, as it relates to X5 and you are more likely to get responses here.
1. this audio integral with the video.
2. I have several video clips with this problem that rendering to a new format which caused the problem.
3 I also have several video clips with this problem that in the source(from you tube)
where did the video come from - what have you done with it.
i just want to know how can i fix it .
erdna
- motherboard: Gigsbyte H81M
- processor: I7 4770
- ram: 16GB DDR3
- Video Card: Intel HD4600
- sound_card: Intel display audio
- Hard_Drive_Capacity: 1TB 7200rp
- Monitor/Display Make & Model: Panasonic TX32cx600e
If the delay difference is constant, just split and shift audio. Uf it builds up while playing, adjust audio speed.
i need more information how to do it with preview mod.
change the speed of the audio will spoil it?!
i wait for ansewr.
erdna
- ram: 16GB DDR3
What is "preview mod"?llr wrote:i need more information how to do it with preview mod.
Audio will not be spoiled with those small speed corrections.
it is not work at all.
i will work with virtual dub, that has:
1.direct stream copy.
2.audio skew correction.
with all respect to corel . it cant fix a little problem like sync audio in video file,when the audio play to early or to late.
erdna
- ram: 16GB DDR3
OK VD is a nice program, and it's free. but not an NLE. I use VD quite often but not for those simple tasks like synching audio which Video Studio, and many other NLE's solve since many years.
ok/
but corel program cant fix this problem and without direct stream copy.
