My video with IFrame at 100Mbps shows green video within VS Pro X6.
With VS Pro X2, it is showing fine.
Any help is appreciated.
Video was recorded using Data Video HDR-45
Video details:
File format: MPEG-2 (Transport stream)
File size: 4,182,000 KB
Duration: 317.280 seconds
Video type: MPEG-2 Video, Upper Field First
Total frames: 7,932 frame(s)
Attributes: 24 bits, 1920 x 1080, 16:9
Frame rate: 25.000 frames/sec
Data rate: 100000 kbps
Audio type: MPEG Audio Layer 2 Files
Total samples: 15,229,440 Samples
Attributes: 48000 Hz, 16 Bit, Stereo
Layer: 2
Bit rate: 384 kbps
IFrame at 100Mbps shows green video with VS pro X6
Re: IFrame at 100Mbps shows green video with VS pro X6
Welcome to the forums!
Frankly, though, I have no real idea what could be causing that problem as we don't get many users with equipment like your Datavideo recorder which can produce video at that high bitrate. I am also surprised that X2 seems to show it properly since it is now a rather old program. Have you tried X6 with video recorded at the slightly lower Datavideo bitrate in the 20 - 60 Mbps range? If so, how does that appear?
And have your tried rendering a short clip of the 100 Mbps video to a new video? How does the resulting video look -- also green? What does Share > Create Video File > Same As First Clip produce?
Sorry not to have been of more immediate help but most of us are just starting to feel our way into these new areas of high bitrates (me with a GoPro Hero 3...) Hopefully someone else with more experience in this area will soon jump in with more useful suggestions...
erdna
- motherboard: Gigsbyte H81M
- processor: I7 4770
- ram: 16GB DDR3
- Video Card: Intel HD4600
- sound_card: Intel display audio
- Hard_Drive_Capacity: 1TB 7200rp
- Monitor/Display Make & Model: Panasonic TX32cx600e
I suppose you have your 100Mbps (moving) video on yr PC HDD. Is playback OK with a standard SW player (WMP, VLC,...) on your PC
Thanks for responding.
We didn't mean to record at 100mbps. But we got this new equipment and someone set it wrongly at 100mbps.
So now I have to salvage the video by editing it to lower bitrate.
What I mean is the video generated will have green running video, with no images at all but audio is running fine.
Playing the 100mbps m2t file with sw player is fine with VLC and Nero Showtime.
But with GOM it keeps crashing even with the latest version, and with windows media player it is showing black screen. So source video itself is not exactly right I guess.
BTW, if I just drag the file to timeline, don't click anywhere on the timeline but just click play button for preview, the video on the preview window runs fine, showing me the video. The moment I click on the timeline or drag another file onto the timeline, video on preview screen becomes green.
Actually I am happy with pro X2 but we just got new laptops with windows8 and so have to consider upgrading to Pro X6.
Thanks again for all the help.
Actually was a mistake on our side.Ken Berry wrote:Welcome to the forums!![]()
Yes, at lower bitrate it runs fine.Ken Berry wrote:Welcome to the forums!![]()
it generates just green video also when I render it as DVD format or 'same as first clip video'. But audio is fine.Ken Berry wrote:Welcome to the forums!![]()
