Is there anyway to out the most useful things..
TheNoodler
motherboard: Hewlett-Packard HP EliteBook 2540p
processor: 2.13 gigahertz Intel Core i7 L 640
ram: 8gb
Video Card: Intel Graphics Media Accelerator HDHigh Definit
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 160
Monitor/Display Make & Model: Generic PnP Monitor
Post by TheNoodler »
So, for instance, with the 15.0.2.12, I want the re-size, crop to selection, one stop photo fix, smart photo fix, go with, JPG, GIF, and PNG optimizer?
I always how to do this, there got to be way.
TheNoodler
ram: 8gb
Re: Is there anyway to out the most useful things..
Any takers to this foreseen gesture. I want to open this up using the 5 or six thins to do this.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
I'm afraid I don't understand the question.
Are you asking for a way to make those five things readily available? Like a custom menu or Custom toolbar? Those are possible in PSP. Under the View menu you will find a "Customize" option. This will open up the Customize dialog where you can drag commands into menus, or create new toolbars and drag commands onto these toolbars.
If you're talking about how to open an image and automatically do these things to the image, or using the batch option that becomes a little harder but not by much.
Scripting will let you record the steps and you can just run the script on all of the images that you want. Preferably in interactive mode so you can change any settings that you want to. The hardest one would be Crop to Selection, as you first have to make a selection. And with scripts, unless it's an intelligent script, you have to predefine the selection. And if you want the selection moved or individualized per image that gets a little hard.
TheNoodler
ram: 8gb
All I want to do is make sure the sure things I use most are up there. the six things or seven things, and I want them to stay up there all the time. How do you do this?
ram: 6 GB
My suggestion is a custom toolbar.
Again, under the "View" menu is the "Customize" command. Click that and the "Customize" dialog pops up.
Select the "Toolbar" tab. You can either create a brand new toolbar, or edit a current one. I choose to make my own by clicking on the "New" button. Give it a special name, and an empty toolbar will appear.
Next click on the "Commands" tab. This is a list of all of the menus, and the available commands. Find each command that you want to be on the toolbar and drag it from the list directly onto the toolbar. The command will be added.
Once you're done hit "OK" on the dialog and you'll have your new toolbar. You can leave it floating or drag and dock it somewhere on the screen.
I quickly demonstrated this in a video as well. Hopefully this helps
TheNoodler
ram: 8gb
Is there any way to get rid the icons unused items in their tray, another words I would never use them if anything.
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
While you're in Customize mode, drag them off the toolbar to remove the ones you don't need/want.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
TheNoodler
ram: 8gb
So you are saying to me meet the following icon and they will never show up again, I just want to get this straight. What if wanted back them up?
ram: 6 GB
All available.....well almost all available, commands are listed in the Commands tab. So all of the tools, all of the menu items. Are all right there ready for you to use from the Customize dialog.
Some aren't but it's rare that you'll get rid of those.
So for the most part, if you remove them from the toolbar you can get them back by just coming back into the customize dialog and dragging the commands back onto their respective toolbars or menus.
If you accidentally remove an item that cannot be retrieved from the customize dialog you'll have to do a full reset of your workspace, this will lose all changes you've made thus far. So it's a good idea, once you have the workspace setup the way you want, to save the workspace.
TheNoodler
ram: 8gb
Thank you so much!
TheNoodler
ram: 8gb
Is there any way, to make it here stands out. The only one I want there is the "Crop to selection" to show up? Is there any way to make this default?
LindaSue
ram: 3 GB
Post by LindaSue »
Add the Crop to Selection button to your toolbar.
TheNoodler
ram: 8gb
I installed it already, what gives?
AdrianW
motherboard: ASRock Z68 Extreme4
processor: Core i7 2600K
Video Card: AMD HD7970
Hard_Drive_Capacity: 9 TB
Monitor/Display Make & Model: Dell U2711
Post by AdrianW »
@TheNoodler - I've read this entire thread, and none of your questions make any sense at all. Is English not your first language? Maybe get a friend to translate your questions into English, and don't rely on Google Translate - it doesn't do a very good job.
TheNoodler
ram: 8gb
I installed it already, the "Corel Paint Shop Pro x5. Is there anything else to say?
