X6 install packs via do more tab problem
teleoma
motherboard: X99-S
processor: Intel i7 5820K
ram: 32 GB
Video Card: Radreon R9 280
sound_card: Realtek High definition
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Asus MX299 and Dell 2407WFP
Corel programs: Video X7 Ult PaintShop pr0 Ult
Post by teleoma »
I bought X6 ultimate as an upgrade from X5 and uninstall X5 prior to install X6.
In the Corel Guide of X6, "do more"tab I get new downloads but there are seen as VideoStudio Pro X5 and when installing them this is what I got:
"the installed version of the application could not be determined. The setup will now terminate".
The system has not been modified....""
I already tried these steps without success:
Clearing the temp files (my OS is W8) following the Corel guidelines, then reboot and
uninstalling and reinstalling studio X6.
Thanks for your help
Regards
Martine
teleoma
motherboard: X99-S
ram: 32 GB
Re: X6 install packs via do more tab problem
Post by teleoma »
I just noticed that only the menu packs and the title packs could not install.
Templates and fonts are OK.
Regards
Martine
Regards
Martine
Post by BrianCee »
If you had not uninstalled X5 first you could have just copied them form X5 to X6 - not possible now though - don't know what you can do now.
Perhaps a warning to other users not to un-install previous versions until you have X6 up and running properly .
AussieTX
motherboard: Gigybyte 990FXA-UD3
processor: AMD FX8350
ram: 16 Gig
Video Card: Assus HD 7770 2GB GDDR5
sound_card: On Board Audio
Hard_Drive_Capacity: 2 T
Monitor/Display Make & Model: Asus 23" IPS + Acer 23" IPS
Post by AussieTX »
I noticed the "Do More" in X6 showed that the Title packs were all installed but this was because of the X5 installation.
All you have to do is open X5 and go to the Titles page.
Place all the Titles that are missing in X6 onto the Video track and save the project.
Start up X6 and open the project you just saved from X5.
With the Titles page open in X6 drag all the Titles from the Video track up to the library.
Now you have them all in X6 as well as X5 :)
Jack of all trades,
Master of none!
teleoma
motherboard: X99-S
ram: 32 GB
Post by teleoma »
Thanks a lot, I will try this but have to reinstall X5 first :( which means I think uninstall X6 first to reinstall after X5.
I let you all know.
I open a case with Corel. If I got an answer which works from them, I will post it here.
Have you an idea for the menu packs which also will not install?
Regards
Martine
PS: as conclusion X6 and X5 must be so far installed together
Regards
Martine
teleoma
motherboard: X99-S
ram: 32 GB
Post by teleoma »
Hi every one,
Reinstalling X5, then X6 and manually copying the missing menus from the content folder of X5 to the content folder of X6 did the trick.
But I find this update mode very unusual.
Meanwhile I got an answer from Corel:
_"Thank you for contacting Corel Customer Support.
To ensure that the issue was not caused by either a corrupted or incomplete installer, redownloading the installer is necessary. To avoid this same problem from occurring, kindly disable the following before downloading the installer:
• Pop-Up Blocker
• Anti-Spyware
• Anti-virus
• Firewall
• Other Applications that might be consuming your bandwidth
"_
I will not once again uninstall and reinstall the whole thing. I don't think that my installer is corrupt. I reinstalled without problem but the menu and title packs 4 times already.
Regards
Martine
Regards
Martine
teleoma
motherboard: X99-S
ram: 32 GB
Post by teleoma »
Another tip,
Export the library in X5 under setting/library.
Import the library in X6 under setting/library.
All the titles are now presents :)
Hope this will help
Regards
Martine
Thanks for the info regarding the libraries, not been able to do that in the past, X5 and X6 is the only versions you can do, nice to know.
I will be installing X6 to Windows 7, if it works ok I will test the do-More downloads.
Titles, in the past title 1 to 4 were already installed, Titles 5, 6 and 7 etc would add 10 titles to the library, 10 for each that is.
There were two Menu templates which updated HD menus and DVD menu, not sure which was which.
Check the Gallery contents before installing the Menu packs, that way you will see the additions? Hopefully
teleoma
motherboard: X99-S
ram: 32 GB
Post by teleoma »
This is the last answer from Corel. I hope an update will come
"Thank you for providing additional information. Allow me to apologize for the inconvenience it had caused you. Since VideoStudio Pro X6 is just a newly released product, unforeseen issues like this may crop up. I appreciate your patience and cooperation on trying to resolve this issue.
I can confirm that some templates are unable to be installed directly into VideoStudio Pro X6 especially if you had X5 installed. As you have done, transferring the library contents manually resolves this issue.
Since you had resolved this issue yourself and have contributed information for future cases like this, allow us to extend our thanks. I will now close this case for you. Please let us know if you need further assistance with Corel products in the future.
Regards
Martine
Nice of Corel to extend their thanks………
I installed X6 to a new PC Windows 7, only X6 installed.
All Do More downloads for Instant Projects installed and populated the Library ok.
I have not as yet tested the downloads for Titles or Menus, but have no reason to think they will not work.
I then uninstalled X6 and installed X5, all Instant Projects populated ok.
The files being retained in the VSPTemplate folder.
There were some issues with some X5 templates.
Please see this post. http://forum.corel.com/EN/viewtopic.php?f=1&t=47664
Afaik the templates in this list are no longer available for download, however if you have downloaded using X5 they may/will be faulty. However we can recreate the Instant Projects, fixing them.
I will be downloading the menu and titles just to test those out.
If you are having a specific problem with an individual template, give us some details and we can test the download and installation.
Natal
motherboard: Asus P8Z77-V deluxe
processor: i7 3770K 4.37 Ghz
Video Card: Gigabyte GTX680 OC 2GB
sound_card: System board
Hard_Drive_Capacity: 40 TB
Monitor/Display Make & Model: Samsung SyncMaster S27A850D (2650x1440)
Post by Natal »
Menu pack and menu pack 2 don't work for me either. Nor do the title packs. During install they flash up some messages that seem to indicate that they are for VS5, but nothing installs. They don't say where exactly they are installing to either so the files may well be on the system but who knows where. VS5 wasn't on that computer, so that isn't the issue.
After I close VS6 down, a little widow pops up as "messages" listing the ones that didnt install properly, with a small panel next to the message that allows you to click and reinstall, but nothing happens. So, these particular packs appear to be broken.
Canon Vixia HF G30; Sony RX100M5; Samsung NX1; Nikon P900
Videostudio X6
Creative Cloud CC
Yes you are correct there is a problem, Corel are aware, I have posted an announcement at the top of this forum.
Sorry for any inconvieniance.
Hi Natal
The downloads are saved to a Corel/Download folder.
For Windows 7 64 bit they are within C/ Program Data/Corel/Download
The Instant Projects will then install to
C:\Documents and Settings\User Name\My Documents\Corel VideoStudio Pro\VSPTemplate
Any template folder in this location will populate the library
The menu packs, increase the available Gallery when burning a DVD.
They are installed as UFO files here:-
C:\Program Files\Corel\Corel VideoStudio Pro X6\Content\Menu Template
For W7 64 bit Program Files X86
Sorry not sure where the Title packs install to, I have never looked.
