Can someone tell me how to change the printer associated with PSP or add another printer? I have 2 printers installed on Windows7 but the only one I get when I try to print from PSP is the wide format printer & no option to add another. Is printing from Windows Photo Viewer my only option?
Many Thanks,
MamaWolf
Print Options In PSP9
MamaWolf
- motherboard: Quanta 2ABB 101
- processor: 3.40 gigahertz Intel Core i7-2600
- ram: 16366 Mega
- Video Card: AVerMedia H323 MiniCard Hybrid ATSC
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: HP TouchSmart
- Corel programs: Jasc PSP 9, Corel PSP X4
- hartpaul
- ram: 8 Gb
Re: Print Options In PSP9
Perhaps go to Device Manager in Windows 7 and make the printer you want PSP 9 to use your default printer.
I think the option to use different printers is a windows feature, while other programs including PSP will use your default printer.
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
I believe PSP9 will only use the default printer at the time. This is easily changed however in Windows 7.
Click Start> Devices and Printers. On the Devices and Printers window you should see various printers, right click the one you want to use and click Set As Default Printer. You can do this even if PSP9 is open but not while you're already in the print dialog. Once you're done printing if you want to you can go back to whatever other printer you want as default.
If your other printer is already default then there may be something wrong with the printer or another setting.
Regards, Dan
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
I'd heard that before about PSP9 not having the option of changing printers. I now have PSP9 on my Windows XP computer and I can select a different printer. My version is 9.01. Perhaps the printer issue was fixed with the patch.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
- hartpaul
- ram: 8 Gb
JUst tested on PSP8 and when I try and print from Edit mode I get a Dialog box that under the section Printers has two Buttons Properties far right and beside it Printer... Clicking that allows one to change printers.
MamaWolf
- ram: 16366 Mega
Sorry for taking so long to respond.....crazy PC problems. I have several printers & changed the default so now PSP automatically uses the right one. Thanks to everyone for all the help.
LindaSue
- ram: 3 GB
You should be able to choose any of your printers whether they are the default printer or not. Click the button in the top right corner that says "Printer...".MamaWolf wrote:Sorry for taking so long to respond.....crazy PC problems. I have several printers & changed the default so now PSP automatically uses the right one. Thanks to everyone for all the help.
