Installing of mp3 into vs x5
stanislav318
- Hard_Drive_Capacity: 1000GB
Hello!
I don't understand how to install mp3 into video studio pro x5 ? I am installed k-lite mega codec pack, then, ffdshow_rev4499_20130104.
I am choose *.avi , 30 fps, 800x600 , h264 (from k-lite) (2000 kbs, ultrafast, tuning:film) and want to choose mp3 , but i can't find it.
1question : How to install MP3 into pro x5
I am capturing avi file with (h264, 4000 Kbs, ultrafast) and (pcm,1114 kbs). BUT!!! in "project" mode it is playing very slowly! .. and i must to convert it to mp4 file with h264(4000kbs, ultrafast, level 4.1) and aac(192 kbs). This second file is better to playing in "project" mode.
Is there any problems with avi-container in video studio?? or it is my problem?? i saw that proxy files are dont creating in avi(h264,pcm) ...
so my 2 question is: Why video studio cant read normally and played it in "project" mode normally? where is problem?
thanks for answers.
thanks for answers.
Re: Installing of mp3 into vs x5
Hello
i am sorry but I do not understand what you mean by installing mp3 into VideoStudio - mp3 is an audio format and VideoStudio is already programmed to deal with it.
Why are you installing extra codecs - you do not need to to use VideoStudio - many people have trouble after installing the k-lite codecs
to use an mp3 file just insert it into one of the audio tracks of VideoStudio.
I notice the word "ultrafast" in your mention of the video file - does that mean a high frame rate - how fast ? 60fps or more ?
it is possibly playing slow because VideoStudio is playing it at 25 or 30 fps - is that correct.
VideoStudio is designed to edit virtually all avi files - where do your videos come from - what camera
stanislav318
I want to show you my problem
http://www.youtube.com/watch?v=rIFnVXEJe5s
1. I dont know why my video avi(h264, pcm) not reading in corel studio, OR my video doesn't playing normally (it is playing with stops) ... I want to Corel Studio normally read my video. ELse i must to convert it to mp4 (h264,aac)
2. how to install mp3 ??? It is dont there. I believe you that mp3 is in corel studio , but i don't see it...
i have 2 computers with it problem
windows 7 x32, amd phenom xII, 2 gb ram , 1 gb video ram...
windows 7 x64, i5 , 6 gb ram
...please help me)
...please help me)
Re: Inserting H264 Mpeg4 mp3 audio into vs x5
Hi Stanislav
Wow a lot going on here…………
First
To insert your video file to the timeline, “right click the timeline” and select “Insert Video”
Browse your hard drive for your video, do you see any error messages.?
First
stanislav318
Okay let's start from beginning...
http://www.youtube.com/watch?v=fY8_0VkCmpI
thank for answer
we have video avi(h264,pcm) and it is doesn't normally readen by pro x5 .
either proxy-files are not creating.
i think it is because win7 are not properly installing codecs in it
p.s. yet i create mp4 files .. and it is normally readen by corel vs
thank for answer
Ok so you can insert the video to the timeline.
Right click the clip and select properties, i guess by now we know what they will be but can you post an image of that window?
Proxy files
Right click the clip in the timeline and select "Create Proxy Files"
Go to Settings-Proxy Queue Manager to view the files being converted
Go to Settings - Proxy File Manager to view created files.
Ok
Share Create video File is Same as First Video file available?
Hope i have this correct as i am not on my own PC at the moment?
Proxy files
Ok
stanislav318
this is properties of this file
Admin Note - link removed - the images surrounding the properties box are totally unsuitable for display in this forum - and the pop-up over the image is not acceptable - please post a new link to the properties without any additional images - BC
here I am show you that proxy -files are doesn't create
http://www.youtube.com/watch?v=YvHmokYSDv4
about rendering with first clip parameters ( Share Create video File is Same as First Video file ) don't available =(((
p.s. maybe some problems with installing codecs??
Can you try setting these properties, Share Create Video File – Custom Avi - Options Button
Microsoft AVI files
8 bits, 800 x 600, 25 fps
Frame-based
Microsoft Video 1 (Compression Tab)
15 Key frame rate:, 75% Quality
PCM, 44.100 kHz, 16 Bit, Stereo
Does that allow you to render the video.
Microsoft AVI files
Frame-based
stanislav318
Yes, ofcourse !
but it is rendering very slowly... as i said if i will reencode this file to mp4 (h264,pcm) then it will be render very fast and i am like it. but with your setting it is very slowly rendering.... 1 hour about 3-4 hours rendering vs 20-25 min (with mp4 file)
Problem with MP3 SOLVED! To include mp3 we must install http://codec.kiev.ua/Audio/Fraunhofer_M ... CODEC.html it is Fraunhofer_MPEG_Layer-3_ACM_Pro_Audio_CODEC. Then it is appears in VS PRO X5 !!!
But problem with abnormal reading my files is not solved yet =((( help ((((
stanislav318
i founded reason why my video is doesnt playnig normally ...
http://www.youtube.com/watch?v=Xar_TKKA ... e=youtu.be
sorry - it is not on english ...
reason is : then i put in corel studio avi-file bigger than 2 gb then it is bad playing.... else if i put smaller then 2 gb then it is playing good!
why so?
why so?
Your Video files do look a little non-standard using 800 x 600 and ffdshow that being 4:3.
I would have thought a widescreen aspect would be more suitable.16:9-------1280 x 720 would give good quality.
Where exactly did your video file come from, if you are using a capture card are you able to set the capture properties. Are you limited in using AVI, if so what other codecs are you able to use , if Microsoft DV is available you could try that.
Mpeg2 may be the best especially if you can set HD sizes again 1280 x 720
Mpeg4 may be another option.
Smart Proxy
Have you been able to create Smart Proxy files.
I noticed in one of your videos that you changed the location of the proxy files folder?
Smart Proxy
