VS Pro X5 insufficent memory when selecting certain filters
imtinkman
motherboard: ASRock Z77 Extreme6
processor: Intel Core i7-3770k Ivy Bridge
Video Card: On board cpu graghics Intell 4000
Hard_Drive_Capacity: 500GB
Monitor/Display Make & Model: ViewSonic VX2370SMH-LED
Post by imtinkman »
Does anyone know why I am getting a "insufficient memory" error 15036:0:0 when trying to select certain filters such as "Auto-Exposure" and "Brightness & Contrast"? Other filters can be selected without getting this error.
I am running W7 64 bit.
surogat
motherboard: Asrock A970 Extreme 3
processor: AMD Phenom II X4 955
ram: 16 GB
Video Card: Nvidia GTX 560Ti [448]
sound_card: Realtek
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Philips
Re: VS Pro X5 insufficent memory when selecting certain filt
Post by surogat »
Maybe your Intel HD 4000 is not capable to acquire the amount of video ram to process some filters?
imtinkman
Post by imtinkman »
Solved: Another program was using a file named "libiomp5md.dll". This file is supposed to be the newer version of libguide40.dll that Video Studio Pro X5 runs. Seems Video Studio defaults to this file when starting the program so it disables some of the filters? Solution was to rename libiomp5md.dll to libiomp5mdBAK.dll in the other program. Then, before using the other program change the file name back to libiomp5md.dll. Sounds crazy but that is what it took to correct the problem.
canuck
operating_system: Windows 8.1
Post by canuck »
imtinkman wrote:Solved: Another program was using a file named "libiomp5md.dll". This file is supposed to be the newer version of libguide40.dll that Video Studio Pro X5 runs. Seems Video Studio defaults to this file when starting the program so it disables some of the filters? Solution was to rename libiomp5md.dll to libiomp5mdBAK.dll in the other program. Then, before using the other program change the file name back to libiomp5md.dll. Sounds crazy but that is what it took to correct the problem.
What is the "other program?
imtinkman
Post by imtinkman »
The other program is vReveal 3. It is basically a simple video enhancing program that I use occasionally, but VS Pro X5 is way better for editing videos.
Rawcoll
Post by Rawcoll »
Can I ask
1) How did you find out which dll files the applications were using?
2) Did vReveal3 need to be open for the crash to happen, or was it sufficient that you'd used it in the past?
I'm querying this because this same dual dll issue is causing project opening and other problems with my VSPX5.
