Fade in and out to black?
sentinelrv
Does this program support the ability to start your video with a black screen, and fade in to the movie, and then fade out to black at the end of it? I can only use transitions in between scenes, and not the beginning or end. I am looking, but I can't find these options.
rwindeyer
joosuna
- System_Drive: F
- processor: intel dual core 3 Ghz
- ram: 12Gb
- Video Card: nvidia
- Hard_Drive_Capacity: 2000
Yes, the program allows you to put in a black video clip and then transition from the black to the start of the movie with a "cross fade" transition. Then at the end of the movie just add a black video clip and put in a "cross fade" transition, between the black video clip and the end of the movie, so that the movie fades to back.
The other way is to use the "fade to black" transition available to you in vs8.
Davey
MtCastle
Davey--
When I do this, I start with a black "color" chosen from that category in the dropdown Library. I make the initial black last 3 seconds. I insert a second "color" (blue this time) from the Library, and set duration at 5 seconds. Between those two colors I insert a Transition > F/X fade-out/fade-in.
I position the cursor over my blue, and click "Title" and double-click on the Preview Window and type in my title. Click outside the square, position the title with the mouse, and final click to set. Then adjust the duration of this title to 4secs15frames.
Finally, add another F/X fade-out transition to lead into the movie proper.
