Having recently bought an E-PL5 I was resigned to buying LR4 since ASP doesn't (yet) support the camera. However, ASP does support the E-M5 and I had the hunch that files are probably the same except for the camera type tag. So, I used exiftool to change the 'model' EXIF tag on one of my E-PL5 ORF files to say 'E-M5' and bingo, ASP works just fine.
You can find exiftool here: http://www.sno.phy.queensu.ca/~phil/exi ... l-9.20.zip
The command line to update the model tag is:
exiftool -model=E-M5 yourfilehere.ORF
Hope this helps any ASP users with an E-PL5 (or am I the only one!!!)
Paul
ASP with Oly E-PL5 (and probably E-PM2)
Re: ASP with Oly E-PL5 (and probably E-PM2)
Thank you for that - works fine here also.
Regards
Per
Regards
Per
