I've had a Panasonic GF1 for a long time and have used AfterShot Pro (and Bibble before) for processing the .RW2 raw files.
I just upgraded to a Panasonic G1X and I'm having trouble using AfterShot to process the RAW files.
I'm using AfterShot Pro 1.1.0.30 and I have found a message in this board from Apr 2012 saying that AfterShot Pro 1.0.1 added support for the Panasonic G1X.
However, here's the problem I'm having: When I'm looking at a .RW2 RAW image in AfterShot Pro, the Temp slider is greyed out and when I click on the White Balance pulldown, it doesn't pull down so I can't adjust the white balance.
In the same session, if I look at an older .RW2 RAW image from the GF1, everything works fine.
Curiously, I can click on the click white balance dropper and seem to affect the white balance of the image, but I can't slide the Temp slider to change the white balance.
Similarly the "Highlights" slider and the "Raw Noise" slider are also greyed out.
Am I missing something?
Thanks,
--Jim--
Support for Panasonic G1X RAW format? (.RW2)
Re: Support for Panasonic G1X RAW format? (.RW2)
hi jim,
the few testfiles from the GX1 work fine here with 1.1.0.30
are you sure you are not looking at JPG-files? because then the WB-behaviour would be exactly like you described it.
Bibble since 2004. Aftershot until 2020. From then on darktable.
jjd
- System_Drive: N/A
- motherboard: iMac 2013
My intent was to be editing a .RW2 raw file, though I suppose there is a chance that I accidentally shot something in JPG before I had the camera customized for my preferences.
I have subsequently edited GX1 .RW2 files just fine, so let's chalk this one up to user error.
Thank you.
Thank you.
phew, that's a relief, because the GX1 is my next camera purchase.
henrystahle
- motherboard: Acer Aspire X1935
- processor: Intel Core i5-3450 Multi-core 4
- ram: 8 GB
- Video Card: Intel
- Hard_Drive_Capacity: 1 GB
- Monitor/Display Make & Model: LG Flatron L225WT
I have a new Panasonic Lumix DMC-FZ 200 and I can not use AfterShot for the RW2 files from this camera
. My old Panasonic Lumix DMC LX3 files works fine, they are RW2 files too. Adobes Camera Raw handles the latest RW2 files correct as does the SilkyPix. But not AfterShot. Corel needs to update raw files more quickly, as fast as Adobe does I wish and think, the FZ 200 was released a year ago.
Until Corel fixes this I use the great SilkyPix!
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
GH3 raw file support is also needed ASAP
User for more than 10 years.
tomsi42
There is a new release out now. GX1 is not mentioned in the list of supported cameras, though.
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Maybe not mentioned in the release notes, but look:
Now, I haven't got an RW2 file to try out ....
Code: Select all
strings AfterShotPro | grep -i Panasonic | grep GX
PanasonicDMC-GX1
on 17 Apr 2013, 18:51
so everything is alright. =)grubernd wrote: the few testfiles from the GX1 work fine here with 1.1.0.30
