Still using ancient hw and VS10+. Was able to find a thread close to what I'm experiencing but can't confirm.
No matter, the advice there didn't help with my problem.
I was recently forced to upgrade some [catalyst] driver software and even the MMC (from 9.03 to 9.06).
Cat went from 5.2 to 5.12 for those that understand catalyst versions. Had to update to remedy incompatibilities
with remote wonder drivers. Looks like I may need to update further or back grade somehow.
Recording video from AIW 9800 Pro (ATI Rage Theater Video Capture - Analog cable).
The video showing up in the preview window is squashed vertically.* However, the recorded video appears as it should.
When I capture an image (screen capture) it captures the squashed image, yet the recorded video is as it should be.
This didn't happen with prior drivers and MMC. Is there a setting that controls this? I've tried messing about with the prefs
and such without any change.
* Squashed: VERY large black bars on top and bottom of video and video is stretched out horizontally and smashed vertically
to make everything appear too wide and literally squashed from top to bottom. Entire video (no matter if widescreen or not)
is literally a small sliver in middle of preview window.
I can post screen shot of squashed screen capture image and an image from the recorded video if needed and if allowed here.
There you would see the glaring difference. However, since it SEEMS to be capturing video ok perhaps it's a minor problem.
Also, I don't remember the preview window blanking out (black) when capturing. At least I don't recall (it's been that long since
we've had tv service of any kind).
Edited out redundant hw\sw info
Extra note: video appears ok within it's own [Multimedia Center] tv application.
Are there any guides that help with the settings for this card? I didn't need that before but it appears I do now.
As always any ideas are extremely appreciated - Thank you very much for any help
