zFrame problem
tintin
- processor: Ryzen R5 3600X
Re: zFrame problem
hi,
first you should check your versions of the plugins. there are some effects not onlly wiht the latest version but also with the versions between 1.0.1.10 and the latest 1.2.x.x
the latest versions are:
zFrame: v3.2.0 ( http://aftershotpro.com/plugins/downloa ... ML.afzplug )
zShadow: v2.1.1 ( http://aftershotpro.com/plugins/downloa ... ML.afzplug )
zText:v2.3.2 ( http://aftershotpro.com/plugins/downloa ... ML.afzplug )
if this doesn't help, it is realated to the issue described above already. i'm about to search for the cause of that problem, but till now i didn't succeed, yet. i'll do my best to get it fixed.
br
tintin
br
tintin
tintin
Re: zFrame problem
hi again,
i spent many hours today to dig in the above mentioned problem.
i tried a lot of different things with one test-image that has all 3 plugins zFrame, zShadow and zText enabled and is working fine with ASP version 1.0.1.10.
then i tried several things in ASP version 1.2.0.7....
first i deleted the cache - didn't help.
then i tried many several combinations of the three plugins enabled and disabled, but also with this i couldn't find a scheme that gave me hint where to look in deeper.
in the end i closed ASP and uninstalled all plugins except the three zFrame, zShadow and zText.
then i launched ASP again and viewed and exported my test-image - and then suddenly it worked.
so i thought there is maybe a bad combination with any other plugin and i started re-installing all the other plugins step-by-step.
...and now the mystical thing.... after re-installing all the other plugins my test-image was (or should i say 'is') still working correctly and fast. so i have absolutely no glue what the root cause is/was - maybe this phenomena will appear again when i start ASP on another day.... currently it seems to work fine...
i don't know if this helps, but for now i only can recommend to follow the steps above and hope that it works for you as well.
who else has (or hasn't) this problem and give some comments on this?
br
tintin
br
tintin
Hobgoblin
- System_Drive: N/A
Re: zFrame problem
Hello tintin,
I've created JPGs using the standard ASP Batch Scripts with zFrame, ZShadow & zText all enabled.
http://lukecarville.jalbum.net/JPEG_test/ for examples.
and here is my output from ASP System Info R.
I've had no issue with this on 1.2.0.7.tintin wrote:<snip>
br
tintin
PC(s): Linux Mint 18
Laptop:Linux Mint 18
Photo Software:
Darktable 2.0.4 http://www.darktable.org/
AfterShot 2 Pro
Cameras: Pentax: K-5 & Olympus TG-4
Photo Software:
AfterShot 2 Pro
Re: zFrame problem
Hi TinTin,
My problem is very inconsistent (with zFrame). One picture can take 5 sec to export to jpg and the next one can take 1 min+ and some just stuck in the queue...I think the main problem is zFrame.
Thanks,
Vinny
Thanks,
Vinny
Re: zFrame problem
Hi tintin
I will try the same here and will return with a status. I have the following plugins installed:
Identifier: de.schrell.asGPS
Version: 1.4.1
Path: <User Home>/Plugins/asGPS.afplugin
Name: Black and White
Identifier: com.corel.BlackAndWhite
Version: 1.0.0
Path: <User Home>/Plugins/Black and White.afplugin
Identifier: com.corel.equalizer
Version: 1.0.5
Path: <User Home>/Plugins/Equalizer.afplugin
Identifier: au.com.mindsocket.GradFilter
Version: 2.5.0
Path: <User Home>/Plugins/GradFilter.afplugin
Identifier: sph.SiliconBonk
Version: 0.33.0
Path: <User Home>/Plugins/Silicon Bonk.afplugin
Identifier: com.kbarni.vigne
Version: 1.0.2
Path: <User Home>/Plugins/Vigne.afplugin
Identifier: sph.waveletdenoise
Version: 0.31.0
Path: <User Home>/Plugins/Wavelet Denoise.afplugin
Identifier: sph.waveletsharpen
Version: 1.34.0
Path: <User Home>/Plugins/Wavelet Sharpen3.afplugin
Identifier: tin.tin.zchannelmixer
Version: 2.0.3
Path: <User Home>/Plugins/zChannelMixer.afplugin
Identifier: tin.tin.zFrame
Version: 3.2.0
Path: <User Home>/Plugins/zFrame.afplugin
Identifier: tin.tin.zPerspector
Version: 2.0.1
Path: <User Home>/Plugins/zPerspector.afplugin
Identifier: tin.tin.zShadow
Version: 2.1.1
Path: <User Home>/Plugins/zShadow.afplugin
Identifier: tin.tin.zSoften
Version: 1.1.0
Path: <User Home>/Plugins/zSoften.afplugin
Identifier: tin.tin.zText
Version: 2.3.2
Path: <User Home>/Plugins/zText.afplugin
Regards
Per
Version: 1.4.1
Version: 1.0.0
Version: 1.0.5
Version: 2.5.0
Version: 0.33.0
Version: 1.0.2
Version: 0.31.0
Version: 1.34.0
Version: 2.0.3
Version: 3.2.0
Version: 2.0.1
Version: 2.1.1
Version: 1.1.0
Version: 2.3.2
Regards
Per
Re: zFrame problem
Have installed ASP 1.2.0.7, nuked the cache and removed all plugins. Reinstalled Zframe/zSoften/zText/zShadow and Zperspector, but the problem persist i'm afraid.
I apply my preset using zshadow/zframe/ztext and when processing it, I can be lucky that one single image will be processed, but when i try to make a batch with 18 the program locks up around picture # 8.
The files is raw files from my Olympus OM-D.
If you try to put the preset in the outputbatch it locks up every time.
Regards
Per
Regards
Per
tintin
Re: zFrame problem
mh, now that it works on my machine.... i cannot reproduce this anymore.... could you give me one of your images with the corresponding xmp file? then i could try to test it here on my pc.
br
tintin
br
tintin
Re: zFrame problem
Hi tintin,tintin wrote:mh, now that it works on my machine.... i cannot reproduce this anymore.... could you give me one of your images with the corresponding xmp file? then i could try to test it here on my pc.
br
tintin
Here you go, this set will lock up the output queue!
Only zFrame is used!
https://www.dropbox.com/sh/kmn9in11l12jfxq/kXpLAAfDIR
Vinny
Re: zFrame problem
Yes I can. Download one of the images here:
www.milfly.net/file/090613_OMD_2418.ORF
www.milfly.net/file/090613_OMD_2418.ORF.xmp
Regards
Per
Regards
Per
tintin
Re: zFrame problem
hi,
thanks or the links. i will test it latest over the weekend... before i will probably not be able to get it done.
thanks for your understanding.
br
tintin
br
tintin
tintin
Re: zFrame problem
hi,
finally i had the time to try the images posted above on my machine.
i can reproduce the failure and i'm about to deeply dig in the problem.
i also already find a hint where the problem could be located, but i need some more time for further investigations and trials.
i'll keep you informed as soon as i have news.
br
tintin
br
tintin
Re: zFrame problem
Thanks for taking time to look at this problem.
Regards
Per
Regards
Per
Re: zFrame problem
I will buy you a beertintin wrote:hi,
br
tintin
Vinny
tintin
Re: zFrame problem
hi,
i'm happy to announce that i could fix the problem. since the login to the official plugin site of corel-asp is not valid any more i have to publicize it first via dropbox.
the new version is for first for Win and Linux only, the Mac version will follow soon!
the change-log:
https://dl.dropboxusercontent.com/u/804 ... WL.afzplug
i hope it fixes these issues.
br
tintin
p.s. @Vinny, you can upload the beer here... https://www.paypal.com/cgi-bin/webscr?c ... KGDQ2A6AVQ
the change-log:
- fix: asp hangs up during export of image(s)
- fix: about-dialog freezes in some linux configurations
br
tintin
johanthor
- System_Drive: N/A
- motherboard: Gigabyte GA-Z77 DH3
- processor: Intel 2600K
- ram: 24 Gbyte
- Video Card: Nvidia 660 GTX
- sound_card: Soundblaster Audigy
- Hard_Drive_Capacity: 512 Gbyte
- Monitor/Display Make & Model: HP ZR24w
Re: zFrame problem
Thanks tintin! A beer is on it's way...
Johan
Johan
