zFrame problem
springm
- System_Drive: Q
zFrame problem
To avoid cross-posting:
http://forum.corel.com/EN/viewtopic.php ... 51&start=0
is the URL of a bug report for zFrame.
TinTin, could you have a look at this, please?
---Markus
---Markus
My blog: http://markus-spring.info
tintin
- processor: Ryzen R5 3600X
Re: zFrame problem
hi,
which version of zFrame are you using?
the latest version is available here... http://www.aftershotpro.com/plugins/ind ... lug=zframe
you may see also this thread... http://forum.corel.com/EN/viewtopic.php?f=96&t=48174
br,
tintin
br,
tintin
springm
- System_Drive: Q
Re: zFrame problem
I was already at 3.2.0. Reinstalled it through confirmation that I want to replace the plugin with the same version, but it does still not do as it should. The result is not always the same with different images, but it is never correct.
Now I'll disable all plugins besides zFrame and see if this makes a difference.
---Markus
---Markus
springm
- System_Drive: Q
Re: zFrame problem
ok - zFrame is not the Culprit. If it's the only Plugin, the result is as indicated and expected.
---Markus
---Markus
springm
- System_Drive: Q
Re: zFrame problem
Found it - it was zShadow 2.1.0 - which was not used in this image, mind you. When I upgraded it to 2.1.1a, the output of the conversion was normal again.
Sorry four troubling you, tintin. I could have tried this earlier.
---Markus
---Markus
tintin
Re: zFrame problem
no problem
i'm happy to hear that it works again!
br,
tintin
br,
tintin
tintin
Re: zFrame problem
hi,albernier wrote:hello, thanks for your answer and sorry for my poor English.
I have the latest version of Zframe, but had to backload the previous version of ASP ( 1.0.1.10) to make it work fine..
like posted in the other thread arelady. did you have a look to this thread here? zShadow and zFrame are 'working together' if they are both installed. so the problem can also be that even zF is at latest version but zSahdow is an old one - see also here http://forum.corel.com/EN/viewtopic.php?f=96&t=48174
did you try to run zF as the only installed plugin?
br
tintin
albernier
Re: zFrame problem
thank you very much. Here was the proble. The version of Zframe was the last one, but Zshadow the previous one. With the version of ZS ( 2.1.1.a) , it works fine with ASP 1.1.0.30... Hope it will go on with future versions, ( if they arrive)
br
br
tintin
Re: zFrame problem
...if not, i will update the plugins until it works againalbernier wrote:... Hope it will go on with future versions, ( if they arrive)
br
tintin
albernier
Re: zFrame problem
super! thanks..
Re: zFrame problem
Hi TinTin,
zFrame takes almost 1 minute to output to jpg file in version 1.2.0.7 . It takes only 16 secs when the zframe is disabled. Could you look into it please?
Thanks,
Vinny
Thanks,
Vinny
tintin
Re: zFrame problem
i already noticed the same.... but i have no idea by what this could be caused. the view on the screen is as fast as usual and also the asp-version i used till now is in 'normal speed'.
i will try to dig on a bit more. but it will probably be difficult since the view in asp during the adjustment is ok.
(since corel 'only' updated the supported cams you could jump back to the last version, if you do not need the new supported cams...)
br
tintin
br
tintin
Re: zFrame problem
When using ztext, zframe and zshadow in an output batch on several pictures, the batch stops and ASP locks up. Same problem as I have noticed og the previous versions. I use the latest versions of the plugins. I have returned to the last version working with this output bache 1.0.1.10
Is there any way to get this to work in the new version ??
Regards
Per
Regards
Per
tintin
Re: zFrame problem
maybe. but it will be diffcult. since the plugins are working fine when adjusting the images and only the output batches make problems since the latest versions of ASP, Corel should indicate what they have changed, that the plugin devs can adopt their plugins. or they changed something that impacts the plugin-SDK, but didn't update this... i don't know...mikmak wrote:Is there any way to get this to work in the new version ??
they are telling nothing... so they are maybe not intersted in plugins anymore... the powerful plugin SDK (and the correspondin plugins) once was a really good unique selling point for Bibble/ASP, but now....
br
tintin
Re: zFrame problem
Can see the problem in making changes without getting any informatio.
I have now used the new version of ASP and it is not working for me with zframe, ztext and zshadow. If I apply a preset I can see the change on the screen, but when i try to make an output ASP stops and locks up. I use the plugins to make images like this for my website.
I hope this problem is solved so I can use the new versions. As of now I am back on 1.0.1.10 and here all is working 100%
Regards
Per
Regards
Per
