VS5 - Missing Settings for other than NTSC & PAL
Julianna1990
motherboard: MSI P67A-GD65
processor: Intel Core i7-2600K Sandy Bridge 3.4GHz
Video Card: MSI N460GTX CYCLONE
sound_card: On MB
Hard_Drive_Capacity: 8TB
Monitor/Display Make & Model: ASUS VK266H
Post by Julianna1990 »
Hello, I hope someone can please help me. I have been a user of previous versions of VS...but my last version was VS12 because I didn't like version 3 or 4. Finally I am trying Pro X5 on a trial. I completed a project in Pro X5 but now I want to save it out to my computer. The problem is that when I want to save it I am missing my compression options. My standard procedure was to go --> Share --> Save File --> Custom --> Options --> Compression and I could choose from 8 different Media Types...Now, in Pro X5 I only get 2 compression types...NTSC and PAL...What is going on?? Am I missing something?!
Here are some screenshots...
Version 12:
Version X5:
I have them both currently installed at the moment. Obviously, only running one at a time :)
Thanks in advance for any help you can give me!
--Julianna
Re: VS5 - Missing Settings for other than NTSC & PAL
Post by BrianCee »
the first thing to note is that DVD produces mpeg-2 files, so you have that option - also I don't think anyone uses mpeg-1 these days or makes VCD so those are un-necessary and therefore not included in X5.
BUT - what you are missing is back one stage - after you click "Share >> Create Video File >> Custom" the 'create video file option' opens - towards the bottom of that under the slot where you enter the file name is a drop down labelled "Save as type" - use the little down arrow to open that and select a different type - .avi, mp4, .wmv, etc etc - selecting a different type there will give you a different set of compressions when you go to the options window.
Julianna1990
sound_card: On MB
Thank you for your reply. The new version does a very good job transferring my HD footage to DVD. The difference is that I had to go through an extra burn-to-file process...But this makes the outcome very clear! Thanks for your help.
Julianna
