Essentially I am having lip sync problems with the sound leading the lips. Nothing I have read on this BB to this point has helped.
Details:
XP Pro SP1 (re-install off of the CD)
and later with SP2 including all updates
CPU:AMD Athlon XP 2700+
500 MB ram
80 GB HD with 55 (or more) GB Free, Ultra DMA turned on
Screen Resolution 1024 X 768 Colour Quality 16 bit
All processes not needed turned off via the msconfig procedure.
Capture with both Capture Wizard 3.0 version 3.0.0.5 date Aug 14, 2003
using the ADS Instant 2.0 driver
version 1.40.000 Driver Date of 4/10/2003
and
VideoStudio 7 SE DVD using the DS Instant 2.0 driver and associated hardware
VideoSTudio8 Trial (Cannot capture as the patch provided by Ulead to ADStech evidently does not work with VideoSTudio8 Trial. I will follow up after the holiday)
Property: Video: (Installed as project files in one effort)
MPEG Files
24 Bits, 720 X 480, 29.97 fps
Upper Field First
DVD-NTSC, 4:3
Video Data Rate: Variable (Max 2499 kbps)
Audio Data Rate: 224 kbps
MPEG Audio Layer2, 48 KHz
Property: Project (default)
MPEG Files
Upper Field First
DVD-NTSC, 4:3
Video Data Rate: 6000 kbps
LPCM Audio 48 KHz Stereo
All MPG's captured with either Capwiz or VS7 playback AOK with Capwiz, VS7 and VS8.
I tried Windows Media Player just for grins and the captured MPG worked .
However....
When I go from Clip to Project mode in either VS7 or VS8 I get serious out of sync. File length seems to have something to do with it as tehelonger the file the worse it is.
I created a video with Create a Video File in the Share options of VS7 and had the same problem.
Something that seems interesting to me is that the with the audio leading the video. As I understand it with the classic drop frame scenario the lips are ahead of the talking.
Any suggestions will be appreciated
Another out of sync situation with a twist
Humble1
For the record
In This one instance the lip sync problem with the sound leading the image was caused by my VCR when capturing VHS tapes and live broadcasts.
