non-photo pictures in ASP??
jonr55
operating_system: Linux
Post by jonr55 »
Hi.
How can I display/handle non-photographic pictures in ASP? Or more specific, I'm using Hugin to create panaramas from pictures originally visible in ASP, but after treatment with Hugin, the result is not visible in ASP any more. The same happens if I try to make panorama with GIMP. I'm primarily working with 8bit TIFF to avoid potential 16 bit problems, but even JPG seems not to work. This happens both on Windows and Linux systems, and I'm running at ASP 1.1.0.30. Help is appreciated.
/JonR.
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: non-photo pictures in ASP??
Post by afx »
images larger than 50MP are not supported ;-(
cheers
afx
jonr55
Post by jonr55 »
ok, good to know, and bad news. The TIFF file was bigger, but converted to JPG the size is reduced to 10.5MB, and still I cannot see it in ASP.
/JonR
afx
System_Drive: N/A
Post by afx »
MP!=MB
cheers
afx
jonr55
Post by jonr55 »
Ah, good point. I didn't catch that. But my picture is 18692x1871, which should be prox. 35MPx. Still below. But I found now another thread saying long side limit of 10KPx. Reduction to this size solved the problem so obviously I have hit a capacity limit. Problem considered closed, thanks for your engagement.
/JonR
