I want to read, on the board of metadata, the bit-number, for exemple 12 or 14 for a Nikon . This number appears... and disappears when i close ASP and re-open it. Of course the RAW file contains it, and I can read it with an other soft, as NXView.
Is it a bug?
Cordialement
AlBernier
Bug in metadata?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Bug in metadata?
Just add it to the metadata set via the metadata manager.
cheers
afx
cheers
afx
albernier
Of course I did it with the metadata set manager. That metadata "BITSPERSAMPLE" appears then, but disappears when closing ASP and next opening, while the title remains alone, without the mention "12" or "14" bit..
the other metadata work .
