&Freehand Selection error popping up started today
DWPenner
motherboard: AMD Pumori Base Board Version
processor: 1.90 gigahertz AMD A8-4500M APU with Radeon HD Gra
ram: 7656 Megab
Video Card: AMD Radeon HD 7640G
sound_card: AMD High Definition Audio Device
Hard_Drive_Capacity: 3230 GB
Monitor/Display Make & Model: AMD Radeon HD 7640G
Post by DWPenner »
Nature of the problem: After quite a while of problem free operation (other than operator errors :roll: ) today I ran across two problems that I am not sure are related. I started seeing an error message pop-up:
&Freehand Selection
And in addition a Paint Shop Pro image ( *.pspimage ) I was working on wouldn't save. It would go through the entire preparation and then when the progress bar disappeared a few moments later I would get a message saying there was an error:
An error has occurred while trying to save the image.
I have noted while preparing this topic that the &Freehand Selection error has popped up a number of times... I assume with each attempt to autosave.
Properties of your source files (format, file size, where did you get it?): I created this pspimage file on PSP X5 15.2.0.12 35.010 Mbytes memory used 1200x1200 RGB 8 bits/channel
What devices are involved and their mode of connection? Only the Toshiba laptop, Dynex cordless mouse, and WiFi connection to the Internet. 1 jpg texture file and a jpg background in addition to text. Before photo and graphic editing.
Project Properties ? Just trying to save the pspimage file before exporting a png file to publish online.
Output format Exported PNG file
Error Codes (if any)
&Freehand Selection
and
I had an earlier version saved of course, but could salvage the graphic by copying each later to a new file. I started by copying the background layer, then pasting as new image followed by copying each layer in turn and pasting new layer.
I saved after pasting each layer. No problem with the new resurrection of the file. Though the &Freehand Selection pop up.. popped up. Work got done, thanks to saving work regularly... I've been in IT since the 70's.... you learn after a while. :wink:
Let me know what you think. I didn't want to close and restart until I had a safe copy of the image as I can't save the image I was working on.
Thanks. Perhaps your enlightenment might help others if there is an alternate solution?
Sincerely
DWPenner
