VS4 pro and DVD creation
lilu_hotty
motherboard: MSI X58m
processor: Intel I7 950 3.07 GHz
ram: 6GB
Video Card: ATI HD4800 1024mb
Hard_Drive_Capacity: 6TB
Monitor/Display Make & Model: HP w2207h
Post by lilu_hotty »
Hello
I have VS x4 pro installed during installation i marked it as PAL region. most of my work is pal. but now i need to create DVD in NTSC! why i cant? stupid situation why i cant?
i went to - create disc -> DVD - pops out a new window ..... but i cant choose NTSC any more only pal!?!?! how to avoid it? plz help its urgent
in my previous VS x2 - i was able to chose and pal and ntsc - no problems
regards
WIN7 Pro 64bit SP1, VS Pro X4 SP2, Drive C-WD Raptor, Intel i7 950 3.07, MSI X58m, ATI HD4890 1GB, Realtec HD audio, 6GB DDR3 RAM, Sata II-6HDDs
Panasonic AF101, 1080 25P, Lumix 25mm f1.4, sigma 18-50 f2.8, Rode Ntg2, SDHC SanDisk Extreme 30mb/s 32GB
Re: VS4 pro and DVD creation
In the burning screen, click on the first icon in the bottom left of the screen. It is called 'Settings and Options'. There should be something called "Disc Template Manager", and if you click on that, then you should be able to change PAL to NTSC.
lilu_hotty
ram: 6GB
Ken Berry wrote:In the burning screen, click on the first icon in the bottom left of the screen. It is called 'Settings and Options'. There should be something called "Disc Template Manager", and if you click on that, then you should be able to change PAL to NTSC.
does that option has gone some where? there is still a "Disc Template Manager" , there is also an option to choose ntsc, but u CANT switch to it!!!! why? whats wrong?
plz need some help here!!
i also downloaded a TRIAL of VS ultimate 7 - and here is the same problem!! what is wrong? i cant now create NTSC dvd if i need to?
lilu_hotty
ram: 6GB
also i own all versions since ulead up to corel VSx4 pro and before there were no problems, i was able to create DVD and pal and ntsc ......, but its seems like that they did something with in last update for VSx4 and now that option is gone! i did not notice it before, but now i need to create NTSC dvd and i cant!!!
There are two approaches in burning a DVD disc, creating a Mpeg2 DVD Video File, or burning directly from the timelines, using a VSP file
I assume you are doing the latter. Either way you need to set your Project Properties to use NTSC
With your project open, go to Settings - Project Properties - Edit, change the project properties to use NTSC DVD
Save the project…………
Now Share – Create Disc – DVD the burner module should now be set to NTSC
lilu_hotty
ram: 6GB
lata wrote:Hi
thank you very much! it works!
