hello !
i run my pspx5 (with sp2) on an win 8 pro pc
everythings works fine except within the adjust Workspace
in this Workspace i cannont open files (tab ist grey) and i cannot move
Fotos from my Folders into that Workspace
no Problem within workspaces admin and edit (which is my Standard)
thanks for hints to solve that issue !
Kurt
problem within adjust
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: problem within adjust
Yup I'm seeing the same thing, however, since I don't use Adjust or know how the Organizer is supposed to work with it I did some playing around.
So to give a quick overview of what I do and do not have. I had turned of all cataloging on my system. I excluded all file types, I placed all of my major folders on the "do not catalog" list.
Nothing was showing up, I couldn't drag files in and the manager wasn't wasn't working either. The only thing that worked was edit mode and the organizer wasn't working there either. Though I could still edit photos.
So first thing's first, it's a problem with the Organizer palette not with any of the modes specifically. Though Adjust's reliance on the Organizer is a bit crippling.
The first thing I tried was turning taking PNG files off the exclude list. Nothing showed up, so I restarted PSP and it started to find all of the PNGs in each folder I went to.
So my suggestion is if you've gone to great lengths to stop cataloging, it's officially going to hurt you if you want to use Manage or Adjust. You can tell it not to catalog certain folders and leave the file-types intact so you can still explore with the organizer and it won't catalog.
ok - you're right !
i also have the organizer adjusted not to catalog anything - all formats are disabled and all my drives and Folders
for testing i defined one of my Folders for cataloging - and exactly that piscs now can be handled within admin and adjust
nevertheless a bug or strange design.....
regards kurt
regards kurt
hopefully nobody within COREL will have the idea to design edit mode in that same way that it also
only works out from the Administrator.... !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
