photoimpact 4.2 cool 360
keelmire
Post by keelmire »
Attempting to load program on a new computor?
I get this error
16 bit windows subsystem
C/windows/system32/autoexec.nt. The systen file is not suitable for running ms-dos and microsoft windows applications.
choose close to terminate the application.
Any Help??
keenart
Post by keenart »
Depending on the system configuration, Microsoft Windows XP may delete or modify the autoexec.nt file when upgrading to Service Pack 2 (SP2). This file in not needed by the Microsoft Windows XP Operating System. However, if is required for some 16-bit DOS and legacy Windows applications to run.
When installing a 16-bit DOS legacy program on an XP system with a missing or corrupted autoexec.nt file, the error message such as you received will appear.
To copy the Autoexec.nt file from the Repair folder to the System32 folder, perform the following steps:
1. Click the Start button, right-click My Computer, and then click Explore. (Note: For Microsoft Windows XP systems running in "Classic mode", right-click My Computer on the desktop and then click Explore)
2. The My Computer explorer window appears.
3. In the left pane, click the [+] sign next to your primary local hard drive.
This is normally your C: drive.
4. In the left pane, click the [+] next to the Windows install directory. (Note: For most systems, this is the Windows folder. On some client systems, this is the WINNT folder.)
5. In the left pane, scroll down and click the Repair folder.
6. In the right pane, right-click autoexec.nt and click Copy from the menu that appears.
7. In the left pane, scroll down and click the System32 folder.
8. In the right pane, right-click on any blank space inside the window and click Paste.
keelmire
Post by keelmire »
Thank you very much it worked like a charm
Thanks again :lol:
