I'm new to Motion Studio, I'm using the evaluation version.
I haven't bought the product yet.
Is there a way to improve the output quality of the end product?
I've set the options to "Best" and the size as high as 1920 by 1080 but the final file is very low quality.
I usually work at 1600 by 900 and some times at full HD, but the video looks much more ragged then the animation files that I create.
I could really use this product but I need a better image quality then I'm getting.
I can see that this is probably good enough for online video like YouTube but I'm making files for DVD and computer display.
Thanks for the help.
Mike
I
Is there any way to improve output quality?
Re: Is there any way to improve output quality?
I always output from MS3D using full AVI as the format i.e. uncompressed. And as I mostly do high def video these days, I use a size setting of either 1920 x 1080 or 1440 x 1080 as the defaults. The resulting files are large -- usually around 1 GB for a 10 second title. But I figure I have tons of storage space given the cheap price of hard disks these days. And the quality is always crisp and sharp.
I have played around with other output formats, but like you have not been overly impressed with them.
MikeMoss
- Hard_Drive_Capacity: Ada
HiKen Berry wrote:I always output from MS3D using full AVI as the format i.e. uncompressed. And as I mostly do high def video these days, I use a size setting of either 1920 x 1080 or 1440 x 1080 as the defaults. The resulting files are large -- usually around 1 GB for a 10 second title. But I figure I have tons of storage space given the cheap price of hard disks these days. And the quality is always crisp and sharp.
How are you doing that, I'm not familiar with the software and I haven't been able to find setting to create a high resolution output.
Like you said when videos before compression can be 80 gigabytes what 1 more for the title.
But I haven't been able to create a file larger then about 700 Mb no matter what settings I use.
I saw that increasing the size of the image didn't change the size of the saved file so I figured out that I wasn't gaining anything.
Mike
I usually use the 'Export Video Overlay' option under File. There you are offered only AVI and TGA as possible formats. I choose AVI, and the default settings are Frame Based and Uncompressed at the frame size I have chosen (1920 or 1440 by 1080). Give the new file a name and let it convert. But you should be able to get the same result when you select 'Create Video File' instead and choose AVI as the output.
Some fiddling around in VS might be necessary to get any Chroma keying showing the overlaid title correctly. But the output from MS3D should still be excellent, regardless of any later fiddling!
MikeMoss
I finally found the options in the save menu, and I got a crystal clear 1600 by 900 video.
I was also able to create a nVidia 3D Vision compatible stereo video.
It did distort the image putting the two images side by side in the same frame width as the full image should be.
I just thought, maybe if I make the image size twice the normal width it will come out normal ratio.
I'll try that.
Mike
I'll try that.
Mike
