Menu Items run one after another in sequence on DVD
SabreTooth
Post by SabreTooth »
After burning a DVD with VideoStudio 9, video menu items run one after another and then the process starts over with the first menu item. Is there a way to have a menu item run once and then have the menu reappear?
Thanks,
Jeff
kebrinton
Post by kebrinton »
I believe you determine which of these happens by checking a box during the DVD authoring process. It seems to be accessible when you click the little cogwheel icon at the lower left.
You will see a drop-down option called "Clip playback" and your choices will be "Continue to play the next clip" and "Back to menu." I used to think these choices were only for the burning process, but really they are programmed into the DVD.
SabreTooth
kebrinton wrote:I believe you determine which of these happens by checking a box during the DVD authoring process. It seems to be accessible when you click the little cogwheel icon at the lower left.
Yep, I see it there, and it does offer those options. Will try out shortly.
Thank much,
Jeff
