If I select a curve region and correct then some region points, often moves the complete curve. It's viewable in the 100% view. Hae you any hints.
Frank
Point correction moves the full curve
deranonyme
- System_Drive: N/A
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Point correction moves the full curve
Make sure the point you want to move is selected (red frame).
Zoom to 400% for more control.
cheers
afx
cheers
afx
