Is it possible to make a project with 28.214 frames per second?
My Samsung Galaxy makes videos with 28.214 per second.
Frames / sec
Dirk Jan
- motherboard: ASUSTeK Computer INC.
- processor: Intel Core i5 661
- ram: 4GB
- Video Card: Intel HD Graphics
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: ASUS VH222 1920 x 1080
Frames / sec
Dirk Jan Lekkerkerker
Re: Frames / sec
I don't think you can manually set this rate. But depending on the format of the original video, when you insert it in the timeline, you may be given the option to Share > Create Video File > Same As First Clip, which should give you the same frame rate. Mind you, if you use the default 29.97 fps, I don't think the human eye will see much difference...or can you?
Dirk Jan
- ram: 4GB
Re: Frames / sec
Thanks Ken,
No I can not see the difference, but I think I can hear it. See my post.
http://forum.corel.com/EN/viewtopic.php?f=1&t=49288
I've tried it, but it is not the solution to my problem.
