This may seem a strange question, but I do not work with images very often and having just returned from holiday in NZ (how privileged you are to live there Ken) I have some 30GB of video and almost 1000 images to edit.
These images are 16:9 4000x2248, 180 dpi and 24 bit depth, so is there an optimum resolution that these should be reduced to, for creating projects in conjunction with the video (1280x720 HD 59fps) I read some time ago that images need to be reduced in size, but I can't remember why.
Thank you for any assistance
Robert
Optimum Resolution for Images
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Optimum Resolution for Images
I never ever change the resolution of my images, but what I have found is that you can get distortion if you do not format your images first.
so I always crop my images to a true 16:9 (or previously 4:3) before importing them to VideoStudio - at whatever resolution the camera used.
I do the same as Brian. Keeping the pics to their original resolution also helps if you intended to use pan and zoom on them. If you zoom in on a photo with reduced resolution, you will quickly get pixelation showing up in the video.
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
So ,how do I crop pics to 16.9 as described? I have Paint Shop Pro X and VSX5 Pro.
We have already been through that Kenneth - there is a three page topic which you started with just that question here :-
http://forum.corel.com/EN/viewtopic.php?t=46329
If you still do not have the answer perhaps you could return there and continue that discussion.
