I'm running PaintShop Pro X5 15.1.0.10 on Windows 8 (64-bit). I just tried to create a drop shadow, possibly for the first time since I upgraded from X4, and it just doesn't work. I mean nothing happens.
I added a white border, as usual, and then tried to create my drop shadow. I tried it with the default settings, and I tried it with some random settings. As I said, nothing whatsoever happened.
Inner bevel and buttonize work just fine. (I haven't tried cutout.) Chisel also doesn't seem to work; in fact, it seems to come and go. It's the same with outer bevel: it isn't always available.
I'm not a novice when it comes to PaintShop Pro. I've been using it since it was shareware. I've certainly done drop shadows many times.
I'm completely baffled. Other than uninstalling and re-installing, I can't think what to do.
Drop Shadow doesn't work
jerryschwartznb
- motherboard: Aspen 1.0
- processor: 2.40 gigahertz AMD Phenom 9750 Quad-Core
- ram: 8gb
- Video Card: NVidia GForce 9500 GS
- Hard_Drive_Capacity: 750gb
- Monitor/Display Make & Model: DELL 2408WFP
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Drop Shadow doesn't work
You added a border, did you use a selection to do this?
If so, is the selection still on?
Kathy_9
- Hard_Drive_Capacity: 2TB
Are you trying to add a drop shadow to the entire layer? If so, the bottom layer will need to be larger so there is somewhere for the shadow to fall. I was able to create a drop shadow with no problem in X5. If you are trying to do something else, let us know.
Click image for larger view
