negative picture to positive picture.
paintshop pro4
motherboard: mac-f4238cc8 pvt
processor: 2.40 gig intel core2 duo
ram: 4gb
Video Card: ati radeon hd 2600 xt
sound_card: realtek hi def
Hard_Drive_Capacity: 110.48 gig
Monitor/Display Make & Model: apple color lcd 20"
Post by paintshop pro4 »
I am a newbe with pro4. How do I change a scanned negative image to a positive image? :?: swap black for white and vis versa?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: negative picture to positive picture.
Post by LeviFiction »
Well you can just use the "Negative Image" command found under the "Image" menu.
But if that doesn't produce satisfactory results there was a tutorial posted on this board once about doing something like that with a fairly lengthy process.
paintshop pro4
ram: 4gb
Thanks I'll give that a go. If I can just get a positive image I can tweak it from there.
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Post by photodrawken »
If you've got a black and white negative, obviously the Image...Negative Image option will be all you need.
If you've got a colour negative:
Uploaded with ImageShack.us
then it's a two-step process:
1. Use Adjust...Smart Photo Fix to first get a good range of "blacks" and "whites" in the image. These settings, for example, with a manual adjustment to the "Black" and "White" sliders (note the positions of the black and white indicators below the histogram),
will give you this result:
2. Then use Image...Negative Image to reverse the colours:
The result isn't perfect, but gives you a good starting point to adjust the colours to get rid of any colour cast, etc.
Ken
ram: 6 GB
Here's the post I was thinking of. Someone had asked how to convert a Photoshop tutorial to PSP on doing a Negative color mask.
http://forum.corel.com/EN/viewtopic.php ... ge#p253982
The idea is to get rid of the Orange color cast in the negative before doing the conversion.
photodrawken
ram: 16Gb
Well, after experimenting a bit with this particular negative, the easiest method is to first use Adjust...Color...Fade Correction to get this:
Then, inverting the colours gives this result:
which is actually pretty good.
The bottom line is that there isn't a foolproof method which works for all colour negatives. You'll need to experiment with the various adjustment methods to the negative image (before inverting the colours) to find what works best for a particular image.
Ken
ram: 6 GB
Love the Fade Correction method. Quick and easy, giving an excellent start.
Using the small images you provided I got the best result mixing the Fade correction method and the method for removing the color cast mentioned in the topic above. I overlaid the two results and used a soft-light blend mode.
However, when I took another negative image I found online the Fade Correction is the one that did the best job overall. But, again, got the best result combining the two results this time with Luminance Legacy. So for a starting point, it is excellent.
photodrawken
ram: 16Gb
Aha! I've nailed down The Foolproof Guaranteed Works Every Time method! :mrgreen:
(I found that when I used the Histogram Equalize on the RGB split channels, dark areas of the converted image appeared posterized and pixelated.)
Here's the poop:
We'll deal with two types of colour negative images -- one that does not contain the film edge with sprocket holes, and a negative that does.
A colour negative without the film edges and sprocket holes
1. Here's the original image:
2. Use Adjust...Brightness and Contrast...Curves to set the white point to the palest area of the negative image:
which will give this result:
3. Use Adjust...Color...Fade Correction with the default setting of "45" to get this result:
4. Apply the Image...Negative Image to invert the colours and get this:
Images that include the film edge and sprocket holes
We can use the film edge and an additional step to completely remove the orange colour cast from the negative before inverting the colours.
2. Use the Adjust...Brightness and Contrast...Curves to set the white point to an area in the film edge:
3. Use Adjust...Brightness and Contrast...Levels to set the white point to the same area in the film edge, which will really get rid of the orange background colour cast:
4. Apply the Adjust...Color...Fade Correction at the default setting of "45" to get this:
5. Apply Image...Negative Image to invert the colours:
Ken
photodrawken
ram: 16Gb
To follow up on my previous post, just a reminder that PSPX5 has a terrific feature called "Manual Color Correction" which is especially helpful when images have people in them. You access it by right-clicking on the main standard toolbar, choosing "Customize", and on the "Commands" tab scrolling down in the left panel to select the "Unused Commands" option. Then, in the right panel, select the "Manual Color Correction" item and drag it onto the standard tool bar.
Given the previous result, using the "Manual Color Correction" with these settings and a target colour of "Caucasian skin, light":
will instantly give this result:
Applying an Adjust...White Balance with these settings:
yields the final image:
Ken
ram: 6 GB
That end result you have there, is what I got when I mixed the Fade Correction and Histogram Equalize methods using Soft Light. Well...not exactly of course since they were different methods but they looked pretty darn close.
paintshop pro4
ram: 4gb
Thanks everyone! Looks like I have a lot of reading and tweaking ahead of me.
However it's good to know that it can be done.
Thanks again.
Pro4 :P
