How to use effects from other products (such as VideoFX)
BikerNick
Post by BikerNick »
I have VideoFX from Canopus, but how do I access the effects from within VideoStudio ??
Help
LGO
motherboard: Intel Corporation D915PBL AAC67720-301
processor: 3.20 gigahertz Intel Pentium 4
ram: 3 gb
Video Card: ATI Radeon X300-X550-X1050 Series
Hard_Drive_Capacity: 200-750gb
Post by LGO »
Sorry, don't think that's possible.
Most software is so proprietary that it won't work with features of other software even in the same genre unless they're both made by the same vendor (and sometimes not even then). It's a function of money and marketing - they want all you got.
Of course, someone could prove me wrong. :wink:
Good luck,
LGO
LGO
ram: 3 gb
Post by LGO »
Sorry, must have been hungover when I wrote that last reply :oops: . . .
The last reply meant that you usually can't access the features of one software from another. That doesn't mean you can't still apply the effect.
Do your capturing and editing in VS. Export the clip you want to apply the effect to using a lossless codec, like Huffyuv (avi format). Import the clip into VideoFX and apply the effect(s) that you want. Now, export it using the lossless codec again. Insert the new clip into your VS project (or maybe use it as an overlay?) and you're done.
It requires jumping through a hoop or two, but it probably won't take too much time and the lossless codec will not degrade the quality of the clip.
Good luck,
LGO
THoff
Post by THoff »
According to Canopus, the VideoFX package can be used with both Ulead MediaStudio and VideoStudio. They only list UVS 5.0, 6.0 and 7.0, but that doesn't mean it doesn't work with 8.0 and 9.0.
And then there is the free DebugMode Frameserver, which works with V8.0 and probably V9.0. This would let you integrate different applications and use their respective plugins.
LGO
ram: 3 gb
Post by LGO »
And of course, someone did. :lol:
Thanks for the info, Trevor.
LGO
BikerNick
Post by BikerNick »
[quote="THoff"]According to Canopus, the VideoFX package can be used with both Ulead MediaStudio and VideoStudio. They only list UVS 5.0, 6.0 and 7.0, but that doesn't mean it doesn't work with 8.0 and 9.0.
That's exactly what I'm asking about. HOW do you use them?
VideoFX doesn't have any interface for editing actual video or adding it's effects into video's, ALL it does is create .FBP files which it reckons can be used in VS - but I can't find how to do that in VS.
THoff
Post by THoff »
Disclaimer: I don't have the VideoFX package so I have no first-hand experience with them -- all I can do is glean information from the Canopus forums where I am registered.
When you go to the Effects list in UVS, do you see a new Canopus effect? If so, add that to your clip, and then click on the Options button for the effect -- that should let you choose and customize all of the VideoFX effects. At least that's the way it works with Ulead Mediastudio.
BikerNick
Post by BikerNick »
No, I don't see anything under the Effects. Nothing like VideoFX or Canopus.
