Preset help
brucet
operating_system: Windows 8.1
Preset help
Post by brucet »
I've had some custom Presets that I have been using since Bibble days. I just created a new Preset that has NO noise reduction. No NN and no Raw noise. Both set to 0. I saved the Preset as usual.
Now my problem is that anytime I select that Preset for a file all the setting work except for the noise ones. They stay as per the last selection. eg. If I worked on a file with a NN of 50 everything was ok. But if I selected my new Preset everything changes as it should except for the two noise options. Both stay at the last used value. ie 50. Neither will set at 0.
What am I doing wrong?
thanks.
brucet
Re: Preset help
Post by brucet »
I'm not sure what happened but a Ctrl-R fixed the issue.
Thanks.
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Preset help
Post by afx »
Hmm, looks like your preset was not defined properly, if in doubt, check the XMP file of the preset.
cheers
afx
