I get the following message when I uninstall DMF4 via Control Panel "Add/Revmove Programs"
"Installer has detected that a version of ulead dvd moviefactory 4.0 is already installed in your system. Please uninstall it first and Setup again"
So, I find no way to uninstall it .... any manual procedure or command?
The DMF4 I installed is called "Ulead DVD Moviefactory 4.0 Disc Creator TBYB"
Please help as I find if installed DMF3 SE after DMF4, DMF3 SE is simply failed to run with errors. So, I need to uninstall the DMF4 trial version.
Uninstall DMF4
free3free
Re: Uninstall DMF4
Pls ignore my question... once I remove the DMF4 registry and run the setup again...I am able to select "Remove" option.
free3free wrote:I get the following message when I uninstall DMF4 via Control Panel "Add/Revmove Programs"
