1.1.0.30 crashes when exporting to gallery (XP sp3)
Bugs & Suggestions
FalCT60
Post by FalCT60 »
Hello,
I've got some 320+ files that I'd like to export to gallery.
Before that, I watermarked all photos along each edge and in the middle (4 layers + zText).
The problem is, ASP crashes after processing 1 or 2 photos.
I accidentally created a gallery a few days ago with ASP 1.0.1 (no watermark, though), so I'm sure it used to work. But I upgraded to 1.1.0 now, and wouldn't like to have to go back to 1.0.1... :(
Any idea about this strange behaviour ?
J.-L.
Edit : here are the system infos :
Application vers.: 1.1.0.30
Product Name: AfterShot Pro Registered
Built on: sam. oct. 20 2012
Platform: Windows
Language: fr
App Path: C:/Program Files/AfterShot Pro/build/AfterShotPro.exe
System Home: C:/Program Files/AfterShot Pro/supportfiles
User Home: D:/AfterShot Pro
Prefs Home: \HKEY_CURRENT_USER\Software\Corel\AfterShot Pro
Processors: 2
CPU Threads: 2
I/O Threads: 1
B. In-flight: 1
RAM: 2013 MB
SIMD Version: SSE2
Build Mode: Release
Proc. speed: 2.6 GHz
OS Name: Microsoft Windows XP Professional Service Pack 3
OS Version: 5.1 (Build 2600)
System arch: x32
Memory used: 43%
==================== Plugins =====================
Name:
Identifier:
Version: 1.0.0
Path:
Identifier: de.schrell.asPluginManager
Version: 1.1.0
Path: <User Home>/Plugins/asPluginManager.afplugin
Identifier: com.roland65.AutoLevels
Version: 0.3.0
Path: <User Home>/Plugins/AutoLevels.afplugin
Identifier: com.ferdinand-paris.bez
Version: 1.0.1
Path: <User Home>/Plugins/Bez.afplugin
Name: Black and White
Identifier: com.corel.BlackAndWhite
Version: 1.0.0
Path: <User Home>/Plugins/Black and White.afplugin
Identifier: CAQuest
Version: 2.0.2
Path: <User Home>/Plugins/CAQuest.afplugin
Identifier: com.corel.equalizer
Version: 1.0.5
Path: <User Home>/Plugins/Equalizer.afplugin
Identifier: sph.FatToni
Version: 0.32.0
Path: <User Home>/Plugins/FatToni.afplugin
Identifier: au.com.mindsocket.GradFilter
Version: 2.5.0
Path: <User Home>/Plugins/GradFilter.afplugin
Identifier: sph.grain
Version: 0.31.0
Path: <User Home>/Plugins/Grain.afplugin
Identifier: com.roland65.LabCurves
Version: 0.1.0
Path: <User Home>/Plugins/LabCurves.afplugin
Identifier: com.roland65.LabTools
Version: 0.6.0
Path: <User Home>/Plugins/LabTools.afplugin
Identifier: name.deindl.mdRedEyes
Version: 1.2.2
Path: <User Home>/Plugins/mdRedEyes.afplugin
Identifier: com.ferdinand-paris.mix3
Version: 1.0.1
Path: <User Home>/Plugins/Mix3.afplugin
Identifier: com.SMP.Nostalgia
Version: 1.0.7
Path: <User Home>/Plugins/Nostalgia.afplugin
Identifier: com.SMP.Nuance
Version: 1.0.10
Path: <User Home>/Plugins/Nuance.afplugin
Identifier: sph.SiliconBonk
Version: 0.33.0
Path: <User Home>/Plugins/Silicon Bonk.afplugin
Identifier: com.roland65.USM
Version: 0.6.0
Path: <User Home>/Plugins/Usm.afplugin
Identifier: sph.waveletdenoise
Version: 0.31.0
Path: <User Home>/Plugins/Wavelet Denoise.afplugin
Identifier: sph.waveletsharpen
Version: 1.34.0
Path: <User Home>/Plugins/Wavelet Sharpen3.afplugin
Identifier: tin.tin.zchannelmixer
Version: 2.2.0
Path: <User Home>/Plugins/zChannelMixer.afplugin
Identifier: tin.tin.zFrame
Version: 3.2.0
Path: <User Home>/Plugins/zFrame.afplugin
Identifier: tin.tin.zPerspector
Version: 2.0.1
Path: <User Home>/Plugins/zPerspector.afplugin
Identifier: tin.tin.zShadow
Version: 2.1.1
Path: <User Home>/Plugins/zShadow.afplugin
Identifier: tin.tin.zSoften
Version: 1.1.0
Path: <User Home>/Plugins/zSoften.afplugin
Identifier: tin.tin.zText
Version: 2.3.1
Path: <User Home>/Plugins/zText.afplugin
===> The CRASHLOG folder is empty <===
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: 1.1.0.30 crashes when exporting to gallery (XP sp3)
Post by afx »
zText....
cheers
afx
FalCT60
Post by FalCT60 »
I thought issues with zText had been solved... :(
Thanks,
J.-L.
afx
System_Drive: N/A
Post by afx »
Easy to check,
try the gallery with and without....
cheers
afx
FalCT60
Post by FalCT60 »
It does work with zText uninstalled, of course.
I just meant that, according to this topic http://forum.corel.com/EN/viewtopic.php ... 86#p257074 there should be no more issue.
So, either Corel did something after Tintin updated his module, or I'm the first using zText together with gallery export. :oops:
Tintin, if you read this : it seems your plugin needs some more work. :wink:
J.-Luc
